Brembo Help
Brembo Help
Hi guys,
I have a 2014 GT premium with standard brakes. I decided to do the s550 upgrade (4 pots) that come in the 2018. So I ordered some 2018 calipers but see attached picture. They sent me 6 piston brembos??? Lol so does that mean I gotta get the 15 inch rotors?
Part number JR3Z2B121-A and JR3Z2B120-A . I don’t get it any help appreciated. Thanks
Received 1,496 Likes
yep, I'm pretty sure those are the big ones that go with the 15" rotors
I believe there are some threads on here (in different section) or maybe it was a different forum, with all the details about putting those on an S197 car
if I remember correctly, the calipers will bolt right up, and you need 15" rotors from a GT500, not the new S550 15" rotors because the "offset" is different
also I think there might be an issue with the brake lines; need to be longer maybe? . . . and you need the right bolts and maybe a few other small parts
simpler solution is the SVT GT500 kit, but it's "only" 4-piston calipers and 14" rotors, and the complete kit price is a bit higher than you can source all the parts for
https://lmr.com/item/M2300S/Mustang-...e-Kit-M-2300-S
Those are huge. I would guess yes to the big rotors. Bert knows, believe what he posts.
Yup, definitely for 15” Rotors. Actually the 15+ front bakes in 4 piston flavor are not brembos. Not sure who makes them but they are the cheap brake option. Only the 6 piston brakes are Brembo.
1969 Boss429
10/6/10 07:45 PM
