Brakes
1 Attachment(s)
Little teaser. Some Box Porn.
Ohhh, sexy! |
1 Attachment(s)
Could not help myself. Look at this big sexy Red Caliper. Cant wait to get them installed this weekend.
I have to be honest. Kinda drooling right now. And I haven’t even seen the rotor. |
1 Attachment(s)
Here you go, more parts crack. They are 'yuge' and heavy. 14". I havent attached the hat, waiting on safety pliers and wire coming tomorrow.
And here to think I did good putting the Brembo fronts and GT500 rears on mine, That is true car porn :bling:
Good point Siber! That's the same stuff I have on mine too.
Curious how you like the new ones Rog. Do you have the 13" rotors on yours right now, or the Brembos? It will be a HUGE difference particularly at the track if you had the smaller brakes. Use them well, brake hard and late for the turn in :D Interesting design on the slots. They are symmetrical across the half of the rotor, and not uniform like most. I like that! |
Right on Pat. This is what I would expect. The factory Brembos are actually a really good brake setup for these cars. |
2 Attachment(s)
This should get you excited :heh: (no homo)(NTTAWWT).
(Post 7034801)
Curious how you like the new ones Rog. Do you have the 13" rotors on yours right now, or the Brembos? It will be a HUGE difference particularly at the track if you had the smaller brakes. Use them well, brake hard and late for the turn in :D Interesting design on the slots. They are symmetrical across the half of the rotor, and not uniform like most. I like that! I havent had a chance to install them, too busy working, but looking to get them on this weekend. Patrick, nice brakes, were they a fairly easy install? Any tips? I've been reading the instructions and looking at youtube videos, and it doesnt look too difficult. Of course someone who know's what they are doing make everything look easy. |
Originally Posted by Rog13GTCS
Unfortunately, Brembo's were not an option on the GTCS model, neither were the Recaros. Stock brakes only :( . Hoping for a big braking improvement. Street pads came with the brakes, so I'll need to look for a more aggressive pad when I track it. I did see that Carbotech and Gloc make pads for Wilwoods, will be checking with vendors to see if they can order a set for me.
I’ve never had willwoods. How much work is it to replace the pads? Do you have to take the caliper off or is there an easier way? This is is one thing I love about the brembo calipers. You hammer out 2 small pins the the pads slide right out with the caliper still attached. |
That’s awesome! Makes changing pads a snap. |
One Rotor done! I had to go buy 2 'universal' sockets to work with the 12 point bolts. And also learning to do safety wire. I think I still have some to learn on getting it better.
https://cimg3.ibsrv.net/gimg/themust...f278b31476.jpg |
I got them installed today and ran into an issue as I was running through the brake testing. The right side makes a noise when braking, and I only hear it when I brake or slow down. It is a clicking/thunking noise, it is loud enough to hear in the cabin, and it is definitely not a normal braking sound. I double checked everything and I'm still not sure what the problem is. I check the rotor and caliper for direction. Wilwood has arrows point the wheel rotation, and I have them correct.
There is no rubbing, and there is plenty of room between the wheel and caliper. I checked the torque on the caliper and it is correct. Any suggestions? https://cimg4.ibsrv.net/gimg/themust...d3eb089303.jpg |
Hmm, did you lubricate the pad shims? |
(Post 7034969)
Hmm, did you lubricate the pad shims? Reassembled, and I went through the bedding process, and it sounds better. There is still some some noise present. I was going to let the brakes cool and go out for a spin. I found this youtube video The pedal is firm and it brakes hard. Under light braking I dont hear it, only under moderate/medium braking. Under heavy braking, I may hear it for just a few seconds. If it doesnt get better after driving it more, I'm going to check for lateral run out, and after that contact Wilwood. |
That is a strange one for sure and would drive me nuts as well. I'd do what 5.Monster suggested.
