Worth upgrading to LS swaybar?
Running stock rims and tire sizes for standard Boss but I have utilized the Ford Racing Boss lowering springs. I have a line on the LS front and rear swaybar at a good price and an wondering if I should get an install them?
No. The LS cars have different springs too so they won't be a match. Look for adjustable sway bars if you're going to change them out.
And the reason they had different springs, shocks and sway bars was due to the R-compound tires.
I would think you would want to get an adjustable if you're switching.
Originally Posted by Brandon302
(Post 6662263)
IMHO, Wayne |
Thx. I'll be passing on the $100 set then. On another note, I do intend to go to LS rubber at some point as budgets and time allow.
Originally Posted by Fenderaddict2
(Post 6662359)
Originally Posted by 5 DOT 0
(Post 6662410)
The Pirelli Corsas? Look elsewhere. Expensive, don't last long and chunk when pushed hard at the track. For really good street tires that can work at the track look at the Michelin PSS.
Whiteline adjustable sway bar with adjustable drop links. 475/lb front springs,Vorslage camber plates and AST shocks. The corsa tires are sweet for track and last. Yes they are an expensive tire and you will have trouble with any tire if you push the car hard and don't make changes to the front suspension.. Just my 2 pennies. |
Originally Posted by jim woodruff
(Post 6662487)
Let me give you a different view. While I agree with the above,I could not understand why. I had run the Corsas on my Porsche with great performance. After burning up the corsas on the front with 2.8 neg camber why. The roll center was much higher. Changes made to the front were
(Post 6662534)
Jim thanks for the feedback on these. Most, if not all, of the poor Corsa tire wear has been on stock suspension including a friend of mine with a Boss. I've personally seen these tires chunk in the middle on their second track day with two sets of tires. No doubt they are sticky though.
The michelins aren't really rated for our weight, and the Bridgestone Potenzas I switched to while sticky have too much flex in the sidewalk which makes this sensitive chassis seem bouncy.
(Post 6662359)
They are a great tire, and worked really well for me. When I see people bashing this tire, my first reaction is they don't understand "tire science". These tires require some knowledge to use properly on the track. Mainly, you need to warm them up before pushing them hard and don't over inflate them. As noted above, your car suspension should be stiff enough to handle this compound. Read the reviews. They are stellar, but some people have bad experiences with this tire who don't understand how to run R-compounds properly or manage tire temps and pressures, so do your homework and enjoy them! PM me if you're interested in a pair of rears. Priced to move! |
Originally Posted by DGRacing
(Post 6663030)
I have a pair of Corsa rears. Brand new. Stickered. For sale cheap (I switched to 18" wheel).
(Post 6663296)
I wish you had fronts , I would take them. Still have a set of new rears. What size 18" tires did you put under the car?
(Post 6663030)
I have a pair of Corsa rears. Brand new. Stickered. For sale cheap (I switched to 18" wheel). They are a great tire, and worked really well for me. When I see people bashing this tire, my first reaction is they don't understand "tire science". These tires require some knowledge to use properly on the track. Mainly, you need to warm them up before pushing them hard and don't over inflate them. As noted above, your car suspension should be stiff enough to handle this compound. Read the reviews. They are stellar, but some people have bad experiences with this tire who don't understand how to run R-compounds properly or manage tire temps and pressures, so do your homework and enjoy them! PM me if you're interested in a pair of rears. Priced to move! |
Keep in mind the Corsas were not designed for the Boss, but for the M3, so there have been issues with the tire on our car. There are a ton of tires out there that are great for the street , but if you are going to track the car you may want to go the direction the bulk of the track rats have gone -- 18s. Rims are relatively reasonable and an extra set with tires will fit just perfect in the back seat. Run the Pirellis that came with the car for the street , and go more aggressive for the track -- just an additional thought.
Originally Posted by Fastoldman
(Post 6664043)
(Post 6664210)
Going to start pricing 18" rims.
I would add that don't just buy any old 18" rim. The cheapy street rims are designed for street speeds and I wouldn't run them on the track for the pounding I put down. If you want safety and lightweight performance it's worth paying extra for rims designed for the track or at least forged.
Just my opinion. |
Thinking the whole rim/tire thing might just have to wait till next year. Too much research needed and not enough time, plus I need to put some money in to fixing some very bad road rash.
