2012-2013 BOSS 302
Update on Lowered Boss
Old Feb 18, 2016 | 07:43 PM
fking1's Avatar
Just swapped out rear H&R Sports for Steeda Boss's with one coil cut off.
Left H&R's in the front.
Stance is now exactly what I wanted.
Old Feb 19, 2016 | 11:15 AM
Krohn's Avatar
Looks great! How's it handle though? I haven't looked into the differing spring stiffness.
Old Feb 19, 2016 | 01:48 PM
Coyote5-0's Avatar
Isn't cutting springs frowned upon from an engineering standpoint?
Old Feb 19, 2016 | 02:00 PM
fking1's Avatar
Cutting progressive rate springs is frowned upon. The bottom couple coils on the rear Steeda's are very close together so the spring rate should not be affected much. Cut one coil. H&R coils are farther apart.
Have not been able to autocross yet to judge handling but the ride is stiffer than the all 4 H&R's or stock. Need to cut the bump stops as they are hitting.
Old Feb 19, 2016 | 07:38 PM
PJRManagement's Avatar
Currently a Corvette Owner!
Hi Fred, great picture, love the SBY boss. I just sent you PM with some questions, thanks.
Old Feb 19, 2016 | 07:50 PM
fking1's Avatar
Answered.
Hope this helps.
Cheers
FK
Old Feb 20, 2016 | 12:42 PM
boss man's Avatar
If I may ask: What about your pinon angle and lower control arm angles and axel centering.
Last question, are you running a 1 piece DS or stocker.
Very interested on your findings after you put the car on the autocross coarse.
Old Feb 20, 2016 | 07:18 PM
fking1's Avatar
Last question, are you a 1 piece DS or stocker.
I have new lower control arms matched to the old H&Rs and an adjustable panhard bar for axle centering.
Stock DS.
1st autocross with this set up will be May1, at SCCA Toledo Airport. 7 or 8 more this season.
trackpack13gt
2012-2013 BOSS 302
Feb 18, 2016 12:17 PM
Feb 16, 2016 09:57 AM
