2012-2013 BOSS 302
Oil change at 1k miles?
Old Nov 12, 2012 | 04:54 PM
Dayve's Avatar
I got my first oil change today at 1100 miles. I have always heard about metal shavings getting into the oil and that you want to do the first change at about 1k miles. Any truth to this? I did it and feel good about it, kind of like breaking in the engine for the first 1k miles. It took 7 quarts, or was it 9 quarts of oil!
Dave
Old Nov 12, 2012 | 05:10 PM
t-fatty's Avatar
I did mine at 324 miles when i did suspension and will do it every spring when i take it out of storage - about 1500 miles.
Ohh and get ready for this and that etc as in too soon.
Old Nov 12, 2012 | 09:50 PM
Snowman's Avatar
I also had my first change done relatively early. It's probably not necessary. Some on these forums have posted that it can even be harmful, or at least keep the car from breaking in as quickly as it should.
No problems on mine as of yet.
Old Nov 13, 2012 | 07:26 AM
davesvt2000's Avatar
I did my first in June at 2500 miles.
I'm now watching the oil monitoring system, which currently says 31% life.
The car is put away for the winter, so I'll probably do the next oil change in the spring, late April early May.
Old Nov 13, 2012 | 09:01 AM
GrabberBlue310's Avatar
I changed mine at 1k
Old Nov 13, 2012 | 08:52 PM
jouster's Avatar
Dave
It's not manditory, but it's always a good idea to do the first oil change around 1000 miles or so.
On the Boss, it's also a good idea to check the dipstick level frequently for the first couple thousand miles too. Even though its synthetic oil, the high performance engine will use some during break-in, and you'll probably have to top it up.
It's a personal preference, but before the first oil change I like to put a few drops of oil from the dipstick on my thumb and rub it with my index finger. You can feel the metal filings increase as the engine break-in takes place.
Cheers,
Jouster
Old Nov 13, 2012 | 10:06 PM
Dayve's Avatar
Thanks guys. I plan on keeping my Boss for a long time. I want to break it in properly, maybe going overboard a bit, but I would rather error on the side of caution. How many quarts of oil did your Boss take?
Dave
Old Nov 13, 2012 | 11:21 PM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
Cheers,
Jouster
If you can feel metal filings on your fingers, you've got problems that an early oil change isn't going to fix.
Old Nov 14, 2012 | 11:51 AM
hori's Avatar
for sure..
Old Nov 14, 2012 | 01:42 PM
aircare84's Avatar
Dave
8.5 qts.
Did my first change around 1100, 2nd @ 5K. Will be changing every 5K, or around twice a year.
Old Nov 14, 2012 | 02:26 PM
KeavDog's Avatar
About to do my first. Hoping they don't have the same gorilla that works at dodge. Increadible how tight the torque the filters at the factory...
I have tools now to combat these gorilla mechanics.
Old Nov 14, 2012 | 02:29 PM
Like Father...
I ♥ Sausage
I know what you mean. I like to have never got the one off of my '08 SGT, luckily the one on my 500 came right off.
Old Nov 14, 2012 | 03:22 PM
I was able to get the factory filter off with my hands. Did not crush it or mark it up at all.
Drained the oil out, cleaned it up, and for some weird reason put it away.
Maybe someday it will be worth something on ebay
Old Nov 14, 2012 | 03:49 PM
BLAZN BOSS's Avatar
Cheers,
Jouster
What????????????????? I'm sorry, i usually dont comment on this because it is preferance.........but that statement is horse crap!
Old Nov 14, 2012 | 06:39 PM
KeavDog's Avatar
That's encouraging, unless you're popeye. Went out with my wife in my suburban and the change oil warning came on... Just finished that one. Now on to the boss.
Btw back to chuckwalla tomorrow night on the track Friday. The suburban is my tow vehicle.
We will see if my oil receptacle is really 15 qts. Lol
Old Nov 14, 2012 | 08:51 PM
KeavDog's Avatar
Okay that was like the Exxon Valdez. Between the angled oil filter dripping on the chassis and the oil pan draining into the transmission scoop there is a good clean up job after everything's done.
Filter came off easy with mild wrench pressure.
Old Nov 15, 2012 | 01:45 PM
fbbob96's Avatar
I changed mine at 1000k miles and will do it at 5k and every 5k after that.
Old Nov 15, 2012 | 10:04 PM
jouster's Avatar
Geez, Where do you guys hang out for fun,....
Have you never felt the oil dipstick of a car with the first 1000 - 1500 miles during break-in on it?
Squeez a bit and you CAN Feel the miro metal particles.
I'm not talking a sack of ground metal here! Sheesh!
Old Nov 15, 2012 | 10:11 PM
Like Father...
I ♥ Sausage
You must have some sensitive hands.
Soft, supple.
Like a lady.
Old Nov 15, 2012 | 10:39 PM
Brandon302's Avatar
Dave
If you want to keep the car fr a long time as you have said I would consider changing the oil every 3k miles or so. Yes it's synthetic, and yes I am sure some guys change it later then that because it doesn't given driven super hard, but if you want to err on the side of caution it can't hurt after the first oil change.
