Notices
2012-2013 BOSS 302
The Boss is Back! 2012 Boss 302
Old 8/25/10, 03:42 PM
  #601
Overboost's Avatar
Yeah, there's more to the story than we know right now.
Old 8/25/10, 05:41 PM
  #602
trahsub's Avatar
All I can say is this has nothing to do with mykey. However, you will refer to this as 'my key' after a track session.
Old 8/25/10, 05:56 PM
  #603
Curses.
Now I want one.
Old 8/25/10, 07:27 PM
  #604
Minicobra's Avatar
Originally Posted by Dr Evil
It looked like he almost went along and explained the key but then caught himself when he remembered there was a camera there. I imagine these guys have told alot of people about the secret stuff off the record.
This was probably planned, just to create more excitement, i'm excited!! release the hidden specs and prices already!!!
Old 8/25/10, 08:17 PM
  #605
MustangFanatic's Avatar
Definitely would seem the key offers two settings - street tune and track tune. Track tune is simply going to be bad a__! I just hope Ford offers that on both the LS and Boss 302 models!!
Old 8/25/10, 11:24 PM
  #606
blksn8k's Avatar
Originally Posted by mseymour3
Yeah. He thought he was in trouble for a minute. Another note, that thing sounds absolutely amazing at the end of the video.
Could it be something as simple as they have added the electric motor driven exhaust cutouts on the LS that they said an owner could add on his own? Might explain why the LS they were listening to had that burbly, popping exhaust note.
Old 8/26/10, 06:05 AM
  #607
Whammer's Avatar
Umm...No.
Old 8/26/10, 08:26 AM
  #608
swa737's Avatar
I was thinking the same thing. Possibly a different tune and the cutouts!!!
Old 8/26/10, 08:35 AM
  #609
PTRocks's Avatar
Originally Posted by Whammer
Umm...No.
Exactly.
While it has been noted that two LS' they have out for demos are missing the silencer disks for the side pipes, this has little to no effect on power. The mufflers flow better than they needed already.
Old 8/26/10, 08:38 AM
  #610
Overboost's Avatar
I wouldn't be surprised of FRPP has a cutout kit for the Boss in the near future. Since no one has been able to get close and measure, I wonder what the flange size is for the side dumps. It might be a common size that a company already makes cutouts for, and that would make your life that much easier if you wanted to swap them out.
Anyone else notice this thread loads slow?
Old 8/26/10, 08:52 AM
  #611
Automagically's Avatar
Just a guess here:
I don't think those Boss' on the videos are on full dump with the exuahst. They are much more aggressive but I think if they were full open, it'd be VERY noticable. Almost like the old Boss 302.
As far as the key goes, my vote is with an unlocked tune. Or just a pimp red key.
Edit: apparently I am wrong about the LS versions. I haven't been able to load the videos recently.
Old 8/26/10, 09:07 AM
  #612
Boomer's Avatar
Originally Posted by Automagically
Just a guess here:
The way it looks, you either have the plate removed and it goes out the side/rear, or plugged and it goes the rear.
There are no straight side dumps
(unless you get a valve insert to close one side or the other)
At least, that's how its written in the articles.
Old 8/26/10, 09:08 AM
  #613
swa737's Avatar
Originally Posted by PTRocks
Exactly.
Not saying the cutouts add power, I'm saying that part of the surprise will be cutouts enhance the sound! Really cool effect!
Old 8/26/10, 09:13 AM
  #614
I'm with ya. I don't know what I was thinking. I knew it had the possibility of putting in your own valve but for some reason I was under the impression that the plate was not solid but more like a filter. Sounds stupid right? Doesn't matter, I'd like to have that option of just removing the plate or keeping it in. I don't really have to do the valve system.
Old 8/26/10, 09:42 AM
  #615
ferrarimanf355's Avatar
Would this key unlock a top speed mode?
Then again, I don't expect the Boss 302 to go 260 MPH...
Old 8/26/10, 10:20 AM
  #616
Whammer's Avatar
That will not be part of the surprise. The enhanced sound with the "quad" exhaust was revealed on Aug 13th when Ford announced they were making the Boss 302 again.
Old 8/26/10, 10:52 AM
  #617
Dr Evil's Avatar
I imagine it will. I think I saw a video about the LS out there that indicated 180MPH top speed, looked around and couldn't find it. Maybe it was in the title of the video. Anyway, I did the calculation and since we know the tire size, trans and rear ratios, 180MPH would be achieved at 8400 RPM in fifth.
I believe that is the exact redline of the grand am cars. Hmmm...
Old 8/26/10, 10:56 AM
  #618
06GT's Avatar
Good lord that sounds great with the side pipes open
Old 8/26/10, 11:07 AM
  #619
trahsub's Avatar
As stated in the original PR:
“We added the attenuation discs to meet legal regulations, but we knew buyers might operate these cars in situations where noise regulations weren’t an issue,” Carney said. “The disc is removable and includes a spacer plate sized to match aftermarket exhaust dump valves. If an owner wants to add a set of electric valves, they just undo two bolts on either side; the disc and spacer slide out and the valve will slide right in. And the side pipes are tuned so that drivers can run wide-open and the sound levels are comfortable – very aggressive but livable for an all-day track outing.”
Carney further explains the thinking behind the unusual step of an OEM easing aftermarket component installation. “We’re Ford engineers, but we’re also enthusiasts,” he says. “We understand owner mods are part of the Mustang experience, so we try to help where we can.”
  #620
Whammer's Avatar
There is a clue in the following quote-
“In keeping with the spirit of the original, the new Boss 302 engine achieves its maximum power output at speeds at or above 7,500 rpm".
So how does a car with a rev limiter set to 7,500 achieve revs above 7,500? The only way would be by having a setting that increased the rev limiter on the car. So that's what the "secret" key will allow.
Quick Reply: The Boss is Back! 2012 Boss 302
