Steeda Front Swaybar Endlinks - Street/Comp
Former Vendor
Steeda Front Endlinks - Street/Comp - 05-13 - $129.95
Please let me know if I can help with this!
They're back! Our once discontinued street and race adjustable swaybar end links are back and better than ever!
Steeda's adjustable swaybar end links make a great upgrade for the stock end links as well as the perfect dual purpose street/open track piece.
For street applications these endlinks are as quiet as the factory units. They will not add NVH like rod end units.
For competition uses our double adjustable design makes it adjustable on the car and allows to both retain proper swarbar geometry on lowered cars and adjust swaybar preload for fine tuning.
The adjustment body is constructed from lightweight aerospace grade aluminum and is corrosion resistant. End links feature case hardened ball studs that are greaseable and feature significantly increased swing area compared to spherical rod ends. Includes locking hardware for installation.
Product Benefits
Product Benefits
- As silent as factory units in street use.
- Aerospace grade aluminum center adjusters
- Double adjustable design for adjustment without removing them from the vehicle.
- Case hardened ball stud
- More swing area than endlinks with spherical rod ends
- Proudly made in the USA!
Former Vendor
From a performance perspective they provide reduced compliance (flex) to improve swaybar function and adjustability to get the swaybar pivots level with the control arm bushing centerlines (dotted lines).
From a maintenance standpoint they are a great replacement for when the stock ones wear out.
Swamp Donkey Aficionado
Former Vendor
Please see above.
9/16/15 06:44 PM
9/10/15 12:44 PM
robjh22
9/8/15 12:31 PM
9/8/15 10:45 AM
