New K&N Release - 63 Series AirCharger Intake for 18-19 Mustang models
K&N 63 Series Air Intakes are some of the most powerful intakes on today's market, boasting huge gains in throttle response and horsepowers. They virtually eliminate air path restriction by replacing the air filter and the entire air path to the engine. If you want your new Mustang to breathe easier and perform at its best without any restrictions, you can easily achieve this goal with K&N 63 Series AirCharger® High-Density Polyethylene Black Cold Air Intake System. This kit is used for 2018-2019 Ford Mustang models and features the largest conical shaped high-flow air filter possible. The over-sized filter enables to increase the airflow and let your engine breath easier. Dyno-tested for guaranteed results, this air intake system can get you up to 18.9 horsepower and up to 16.4 lbs./ft. torque. K&N® - 63 Series AirCharger® High-Density Polyethylene Black Cold Air Intake System with Red Filter https://www.carid.com/knn/aircharger...n-63-2606.html https://www.carid.com/images/for-for...ger-must-1.jpg https://www.carid.com/images/for-for...ger-must-2.jpg https://www.carid.com/images/for-for...ger-must-3.jpg Features: - HP Gain: Up to 18.9 hp - TQ Gain: Up to 16.4 lbs./ft. - RPM Gain: 5346 - Air Filter Material: Cotton Gauze - Includes: Air Intake, 5 Stainless Steel Worm Gear Clamps, 2 Couplers - Guaranteed to increase horsepower and improve acceleration - Custom designed and engineered for each application - Works with OEM computer system - Easy to install - Up to 100,000 miles between servicing. Dyno chart for 2018 Ford Mustang 2.3L Ecoboost: https://www.carid.com/images/kn/item...dyno-chart.pdf K&N™ | Filters & Cold Air Intakes - CARiD.com https://www.carid.com/knn/ https://www.carid.com/images/wp/kn.jpg Maximize the performance of your new Ford Mustang with K&N 63 Series AirCharger® High-Density Polyethylene Black Cold Air Intake System from CARiD! |
What are horsepowers? :heh:
