FS: Mustang "HALO" Angel Eye Kit! Single and Multicolor Options! Fits Stock Headlight
Former Vendor
***We have sizes for every Mustang headlight and fog light***
SMD Ring Angel Eyes can be installed on any vehicle as an accent for your headlights. They can be found on BMWs and are a nice modification for any vehicle. Diode Dynamics' angel eyes are the highest quality and brightness available. We encourage you to shop around, you will not find better angel eyes for these prices! Our rings were custom-designed for reliability and long life, and have been tested on your vehicle for perfect fitment.
Our multicolor rings use SMD technology, a modern type of LED that provides a bright forward-firing light, creating a circle of light inside the headlights.
Our newest product, RGB MULTICOLOR angel eyes come with a remote control, in order to pick the color or effect you want. The controller has a static memory, so you can leave the angel eyes switched to WHITE for every time you start your car and drive around, then get out and change up the color! They also come with a custom wiring harness, for plug-and-play wiring, and a standard RGB controller unit with remote. We also offer a WIFI controller option which allows you to control them via smartphone app.
Kit includes:
- Two (2) Multicolor RGB SMD Rings, fitted for your vehicle
- RF 28-Key multicolor remote, to change the color OR Upgrade to Wifi controller
- Diode Dynamics Plug-and-Play Wiring Harness
- Installation guide
- Three year limited warranty
Installation requires you to open the headlight, by using heat from either your oven or a heat gun. It sounds bad, but really isn't too hard. Simply remove all screws, heat the seal, and pull apart. We have installation videos and other helpful guides available at diodedynamics.com/install. The wiring is a plug-and-play installation, using our Diode Dynamics Angel Eye Harness and quick disconnects. You will not have to do any soldering, wire stripping, crimping or anything. Our wiring harness makes wiring a breeze!
Don't want to do it yourself? Looking for a kit for a different model? We can do any vehicle for you, with our large inventory of ring sizes. Contact us for information.
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
2005-2009 Mustang Angel Eye Kit
2007-2009 GT500 Fog Light Angel Eye Kit
If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call us: (314) 205-3033
Research Angel Eyes here on our site: Angel Eyes - Research
Thanks for looking!
Nick C.
Diode Dynamics
RRRoamer
1/19/17 05:27 PM
