Thumbs up Steeda's S550 Tri-Ax Race Short Throw Shifter is Here!
Thought we just focused on suspension? Drivetrain is our forte as well!
Steeda's S550 MT-82 Tri-Ax Race Short Throw Shifter is a full factory shifter assembly replacement for your 2015-2016 Mustang GT or EcoBoost. Our race short throw shifter eliminates all slop and deflection of the factory shifter, and still retains the factory shift knob, pull-up style reverse lockout and backup camera functionality. Product Benefits - 30% throw reduction - 20% lighter than the competition - Eliminates slop and shifter deflection - Shift knob sits 1" lower for ideal 'power shifting' position - Top-loaded installation with adjustable springs, in-car assembly - Retains factory pull-up reverse lockout, OE thread pitch, and back-up camera functionality - Includes Steeda's shifter base bushing bracket - Precision-fit bushings for a direct positive feeling shift - Steeda blue anodized finish - Lifetime Steeda warranty - Made in the USA Steeda S550 Tri-Ax Race Short Throw Shifter - GT | 555-3717 Steeda S550 Tri-Ax Race Short Throw Shifter - EcoBoost | 555-3718 With the replacement of your factory shifter assembly with our short throw shifter, you will notice a 30% reduction in throw between gears. Our shifter assembly will also lower the shift knob by 1", putting it in a better 'power' shifting position. Our Steeda S550 Mustang Tri-Ax Race Short Throw Shifter is quieter than the stock shifter during daily driving, although during race applications you may notice a slight NVH increase. https://cimg6.ibsrv.net/gimg/themust...0886084312.jpg https://cimg5.ibsrv.net/gimg/themust...d35ca01ecf.jpg https://cimg9.ibsrv.net/gimg/themust...b76cb31f03.jpg https://cimg0.ibsrv.net/gimg/themust...8f9b86dab9.jpg One of the great benefits to this shifter assembly is that it's completely top-loaded. Our short throw shifter for your 2015-2016 Mustang GT or EcoBoost comes with 2 different spring set options for a fully adjustable shifting experience. The kit comes complete with 2 medium-resistance springs and 2 high-resistance springs. The Steeda Tri-Ax has adjustable return springs to fit every drivers' preference on shifter feel. Using an offset spring tension ensures that you hit your 2nd-3rd gear change every time. Since our S550 MT-82 short shifter is top-loaded, once the base plate is mounted, you can change all of your springs, levers and other options all from inside the car without taking out the full shifter assembly! https://cimg6.ibsrv.net/gimg/themust...f2a98ada89.jpg https://cimg7.ibsrv.net/gimg/themust...e8719d878e.jpg Our Tri-Ax shifter features rigid mounting in the front and Steeda poly bushing in the rear, virtually eliminating slop and shifter deflection. With less deflection you will feel a much more direct gear change. The assembly is transmission and chassis-mounted so you don't get the 'walking' affect of a fully transmission-mounted assembly, all while still gaining a more rigid shifter feel. Factory shift shaft bushings are replaced with wider, high-quality machine-finished, low-friction bushings. Tolerances are controlled up to a half thousandth of an inch to ensure OE-quality fitment, alignment and shaft actuation. These features alone make our Steeda Tri-Ax one of the most positive feeling shifters on the market today. To top it all off, our Steeda Mustang GT shifter assembly includes Dynamat sound-deadening material to close out your transmission tunnel and ensures your S550 stays as quiet as the stock assembly. https://cimg9.ibsrv.net/gimg/themust...a70283cefd.jpg Steeda's S550 Mustang MT-82 Tri-Ax Race Short Throw Shifter is manufactured from high-quality aircraft-grade aluminum making it 20% lighter than the competitions' shifter assemblies. The shift lever itself on our Tri-Ax is made from heat-treated and nickel-plated 4140 steel, making it the strongest part out on the market. All hardware is stainless steel for the highest corrosion-resistance possible. Included in our kit is hardware to tighten up the factory shift knob perfectly into a locking position. These parts have been put to the test on the street and the track and are proven not to bind under extreme conditions or temperatures. Priced competitively at $439.95 and backed by a lifetime warranty, pick-up one of our Tri-Ax shifters today and shift with confidence! https://cimg0.ibsrv.net/gimg/themust...23e33f236c.jpg |
Looks like a nice piece!
Oh, great
something else I have to look at when the car comes out of winter storage |
something else I have to look at when the car comes out of winter storage Don't hesitate to email me when your ready - tim@steeda.com. Best Regards, TJ |
