Third brake light problem
i have a 2015 convertible. The third brake light isn’t working. Checked and no power at connection in trunk. Anyone know where the fuse is and any other troubleshooting recommendations. Thanks in advance. |
Randy, check your owners manual, It should have the fuse, and maybe even the fix. However, you could always take her to your dealer. That 3/36 warranty should handle it, I think. May wanta check if you decide to go that route.
Same problem no power 3rd brake light
Well? Have you had any luck finding out what it is. I have the exact same problem. No power going to the center brake light. Got a good ground, just no electricity hi. I was thinking it could be the brake light switch on the pedal. But the left and right brake light works fine. Any help would be greatly appreciated. 2015 GT convertible
Mine was having the same issue and it was resolved by having the computer updated.
This image shows what I'm talking about. https://i.imgur.com/0eOS2BS.jpg |
