2015 mustang Air ride, is it the best?
Thinking about getting the air ride suspension kit for my car, what do you guys think worth it or not? pros and cons? I would be getting for the performance not just lowering it for shows if not air ride what's better ?
How much would this cost? I think I would like the versatility of it for sure
For comfort there is nothing better! They do preform pretty well, but aren't the best. A good quality coilover suspension will out perform an air ride suspension, but they are probably the best at everything so as Glenn said, they are very versatile for sure.
1 Attachment(s)
What are you looking to do with the car? I have had my Air Lift kit on the car for a couple weeks now, and it (by far) outperforms every suspension setup I've had in this 2014. Ride comfort, adjustability etc.
As far as handling goes, I need to adjust the collars on the struts and shocks so that I can actually have a ride height that's a bit higher, which will allow me to run less air in the bags, which will allow for a more comfortable ride. At that same time, I will stiffen up the shocks a little bit. I also need to repurchase all the BMR bits I had in the rear and, as I sold all my stuff off to a buddy before I put the Air Lift kit on. Then I'll be able to more fairly judge its capability. Out of the box though, the suspension is amazing. It's a little soft in the corners right now, but the beauty is with some adjustments, it can perform equally to premium coilovers, all while giving you that awesome hard parked stance!! |
