2015 GT w/GT500 wheels
6 Attachment(s)
Turns out the wheels off my 2014 GT work perfectly on my new 2015 Mustang GT w/PP, including ample clearance for the 15" 6-piston Brembo calipers/rotors up front. I measured the backspacing on the factory PP wheels and these are almost identical. Now my Pirelli's can be saved for the summer.
Additionally, it appears the TPMS sensors used on the 2010-2014 Mustang (still in my old wheels/tires) are compatible with the 2015 Mustang, as tire pressures were getting reported from each wheel without requiring re-training for the TPMS sensors. Tires are Michelin Pilot Sport AS3's @ 265/40ZR19 Front and 285/40ZR19 Rear versus the factory PP tires at 255/40ZR19 and 275/40ZR19. Wheels are Ford Racing GT500 Forged wheels: Front = http://fordracingparts.com/parts/par...KeyField=12305 ---- 19x9 with 40mm offset, 6.6" Backspacing Rear = http://fordracingparts.com/parts/par...KeyField=12304 ---- 19x10 with 51mm offset, 7.6" Backspacing Factory 2015 Mustang Performance Package black wheels: (spec's below are molded into the back of the wheels) ---- 19x9 with 45mm offset, approx 6.7" Backspacing ---- 19x9.5 with 52.5mm offset, approx 7.2" Backspacing Photo's on my 2015 vs my 2014 (traded) Attachment 189842 Attachment 189843 Attachment 189844 Attachment 189845 Attachment 189846 Attachment 189847 |
Good to know. I read that the 2015 wheels would not fit 2014 and down. Interesting.
1 Attachment(s)
Originally Posted by kn7671
(Post 6882574)
Additionally, it appears the TPMS sensors used on the 2010-2014 Mustang (still in my old wheels/tires) are compatible with the 2015 Mustang, as tire pressures were getting reported from each wheel without requiring re-training for the TPMS sensors. Tires are Michelin Pilot Sport AS3's @ 265/40ZR19 Front and 285/40ZR19 Rear versus the factory PP tires at 255/40ZR19 and 275/40ZR19. Wheels are Ford Racing GT500 Forged wheels: Front = http://fordracingparts.com/parts/par...KeyField=12305 ---- 19x9 with 40mm offset, 6.6" Backspacing Rear = http://fordracingparts.com/parts/par...KeyField=12304 ---- 19x10 with 51mm offset, 7.6" Backspacing Factory 2015 Mustang Performance Package black wheels: (spec's below are molded into the back of the wheels) ---- 19x9 with 45mm offset, approx 6.7" Backspacing ---- 19x9.5 with 52.5mm offset, approx 7.2" Backspacing Photo's on my 2015 vs my 2014 (traded) Looking good man. I am partial to those wheels myself :) Attachment 189841 |
I kinda like those wheels, too! Biased, I guess!
But, I went with the traditional sizes 255/40 19 F, and 285/35 19 R. I see you changed yours up a bit. Glad they fit the 2015, good for you, enjoy! https://themustangsource.com/forums/...r-speedway.jpg |
1 Attachment(s)
Originally Posted by elkk
(Post 6882584)
They fit great. Wheels off my old 08gtcs Attachment 189838 |
Originally Posted by Anthony k
(Post 6882797)
You probably read what some internet know it all, that didn't even own a 15 mustang posted.
They fit great. Wheels off my old 08gtcs Anthony, wheels look great. Is that Sterling Grey Metallic? Man, I like that. |
Guard green
Thanks. And they r for sale |
Anthony K What rims are those ?? Does your car have the PP ??
Yes it's a performace pack car.
They are Eagle Alloys. Made in the usa. They are my old track wheels from an 08gtcs. They are nice from 5' away. Not show car wheels by any means. No curb marks on the face, but there's a bend on the inside lip. Balance perfect and stable to 150! |
What size are they.. I looked around cant find them.. Who sells them ?? Thanks
Eagle Alloy brand.
20x8 20x10 Discontinued |
OP the GT500 wheels look great on there! Those wheels are so handsome. I didn't realize there was a 285/40/19 size - I am looking into replacements for my stock tires come Spring. I'll take a look at that size! :nice:
Front Page News!
awesome find, we had to share it on the front page!
https://themustangsource.com/s197-wh...mustang-12688/ |
kn, those look even better on your new ride! Eye-popping! But those babies are $500 each? Wow! I couldn't swing it. But beautiful!
:hail:
kn, do you think that means all of the 11-14 wheels should work on the 2015s? I really like the Ford Racing 302S Laguna Seca wheels (11-14: m-1007-dc199lgb) and now I see that LateModelRestoration is even showing them as 05-15 compatible. However, they say that for those wheels, you must buy the splined lug nuts. Any input or comments?
Originally Posted by Salguod
(Post 6917930)
(Post 6917952)
Yes they'll fit just fine, essentially the same size and dimensions as the GT500 wheels in the OP, except they're cast instead of forged. You do need the 2015 style lugs though.
Is it because the 2015 lug nuts are too big in diameter for the 11-14 clearance? |
(Post 6917955)
Thanks, laserred38. That is great! Uh, do you mean I will need the special aftermarket splined lug nuts? And I was wondering if those were rated for 150 ft/lbs (the new spec), tho I suppose they must be...
(Post 6917957)
To be honest, I'm not completely sure. I know they changed the studs on the 2015+, so that's one reason the lug change is needed, but as far as the spline style, I didn't realize the GT500/Boss wheels had smaller lug wells than the standard wheels, so I'm not sure on that.
