no ambient lights
I have a 2013 GT Premium. None of the ambient lights will come on. Not a fuse. What am I missing? Please, driving me nuts! No lights on door sill, inside handle, footwells, cup holder. Car has the adjustable light feature. All other lighting features work and change. (spedo halos and numbers, etc..). And the map lights work but they are separate. Anyone?
Spinning bright to dim dial clicked off?
nothing
All works on the dash menu, but zero elumination. I even pulled out every fuse just to check. Made sure everything had lights to use. Dash menu says all is well and lets me choose colors etc.. Relay bad? if so, what relay? It is a great feature and it has not worked since I bought it used a couple moths ago.
and no, the dial is not twisted off. thanks for the reply. Remains a mystery
no problem
ask away I also think it is something simple. Or at least why it is, and how to fix. Is there a big "on off" switch I don't see? Help me guys. had a 5.0-79, 86,89,95 Some one knows. Help please/thanks jody |
So it did work before, obviously, and you can turn it on or off through the cluster, but nothing happens. I am assuming you looked at the fuse again in case you missed that it is out?
If your cluster dial is turned all the way up and still have no lighting? check your fuses again just to make certain you didn't miss any. If you didn't miss any? it's more than likely one of your relay's or modules need replaced :dunno:
Originally Posted by Gravydog316
(Post 7051642)
is it something in the doors that aren't connected or loose wiring,
like when you close the door, the lights fade out... maybe it's something in your door(s)...? |
I think he's gone.
| All times are GMT -6. The time now is 08:05 AM. |
