Past Rumor Archive All the rumors and media hype for the 2011-2014 model years.
no ambient lights
Old Apr 29, 2020 | 03:51 PM
Ford56860's Avatar
no ambient lights
I have a 2013 GT Premium. None of the ambient lights will come on. Not a fuse. What am I missing? Please, driving me nuts! No lights on door sill, inside handle, footwells, cup holder. Car has the adjustable light feature. All other lighting features work and change. (spedo halos and numbers, etc..). And the map lights work but they are separate. Anyone?
Old Apr 29, 2020 | 03:53 PM
Spinning bright to dim dial clicked off?
Old Apr 29, 2020 | 03:55 PM
Ford56860's Avatar
nothing
Old Apr 29, 2020 | 03:58 PM
Ford56860's Avatar
All works on the dash menu, but zero elumination. I even pulled out every fuse just to check. Made sure everything had lights to use. Dash menu says all is well and lets me choose colors etc.. Relay bad? if so, what relay? It is a great feature and it has not worked since I bought it used a couple moths ago.
Old Apr 29, 2020 | 03:59 PM
Ford56860's Avatar
and no, the dial is not twisted off. thanks for the reply. Remains a mystery
Old Apr 29, 2020 | 05:28 PM
Yep was just asking not to be a smart arz but sometimes it's the little things we don't think of.
Old Apr 29, 2020 | 06:25 PM
Ford56860's Avatar
no problem
ask away
I also think it is something simple. Or at least why it is, and how to fix. Is there a big "on off" switch I don't see?
Help me guys.
had a 5.0-79, 86,89,95
Some one knows.
Help please/thanks
jody
Old May 20, 2020 | 10:18 AM
jim010's Avatar
So it did work before, obviously, and you can turn it on or off through the cluster, but nothing happens. I am assuming you looked at the fuse again in case you missed that it is out?
Old May 23, 2020 | 06:56 AM
m05fastbackGT's Avatar
If your cluster dial is turned all the way up and still have no lighting? check your fuses again just to make certain you didn't miss any. If you didn't miss any? it's more than likely one of your relay's or modules need replaced
Old May 24, 2020 | 09:44 AM
jim010's Avatar
Originally Posted by Gravydog316
is it something in the doors that aren't connected or loose wiring,
like when you close the door, the lights fade out...
maybe it's something in your door(s)...?
If it was an issue in the door, then only the door light would not work. With all of them being out, has to be fuse or the connection before the circuit splits off to go to separate parts of the car. Replace the fuse anyway, just to rule it out.
Old May 24, 2020 | 02:33 PM
jim010's Avatar
I think he's gone.
darkhorse93
Jul 17, 2012 07:41 AM
colbymh
Jan 10, 2008 01:13 AM
allj
Oct 10, 2007 08:23 AM
