What the **** Is this noise!!!!
So I have a 2010 gt and tonight I pulled out of my girlfriends driveway and she called me about 5 min later saying she heard a ticking noise so I pulled over into the Kroger parking lot and put my car in reverse, turned the wheels to the right and backed up and I heard a ticking noise coming from the front right tire! I have no clue what it is, it sounds like "tick...tick...tick" and the faster I back up the faster the ticking gets! Please help!!!
I'd say the first thing to do is check if there is something stuck in the tire. Have you looked?
Originally Posted by jmaStang
(Post 6442085)
It's a rock in the threads
Sounds like clicking when u drive |
Originally Posted by HizliBullet
(Post 6442356)
Had a similar noise driver front on my 2010 GT. checked every tire for rocks, nails or any other foreign matter in the tread before taking it to the dealer. They found a small amount of grease on the front wheel bearing cap. They replaced the bearing and the sound went away.
Hurry and inspect the whole tire. Wouldn't want it to be a screw or nail already embedded and rolling it will just dig it deeper.
I would advise you to take the car to your dealer immediately and have him let all the air out of the tires and replace it with fresh air. Canadian air would be best, if he can get it. If imported air is unavailable, try to get air from the Ozark Mountains.
Originally Posted by Mickstang
(Post 6442988)
I was thinking wheel bearing. but first check the treads.
(Post 6442988)
probably those high canadian air tread rocks...
(Post 6442988)
Helium is an entirely acceptable substitute, but most drivers are unwilling to put up with that irritating high-pitched (like Mickey Mouse on crack) shriek when they break the tires loose on warm pavement. It doesn't seem to bother the Reaper, but I find it objectionable, myself.
(Post 6443789)
And add some weight in the rear for better traction; I'd suggest bagging up all the bull$#!t we've laid down in this thread and tossing it in the trunk.
We here in the Navy often feel that Bulkhead remover is a good solution for this sort of noise. Failing that, a few feet of gig line will fix 'er right up.
| All times are GMT -6. The time now is 04:19 AM. |
