weird thing happened trying to put in sport mode
Hey guys, New around here.
Anyways, I tried to put my '11 mustang gt/cs in sport mode today.
Hold brake, tap traction button twice.
Didn't seem to work.
So, I turned car off. Put ignition in second position not cranking it over.
Tried the brake, 2 button tap. Message came up "sport mode".
Fine.
Tried cranking it over. Weird screech noise.
Now i just get click, click, click from battery. Neighbor tested battery,it's bad.
I don't know if it's coincidence, that the battery all of a sudden went bad,or did I screw something up putting sport mode on while ignition is in 2nd position?
Fine.
Thanks for replying , guys.
We put a portable battery jumper on, and the car starts right up.
Drove it for around 10 mins. Turned it off. click, click, click.
So, I have it scheduled for an appointment at the Ford dealer for tomorrow.
They said the battery should be under warranty if that's the issue.
I would imagine the problems isn't that the battery failed because you tried to put it in Sport mode, more the Sport mode didn't work because the battery was already failing.
A failing battery can cause all sorts of odd scenarios before it dies completely.
That makes sense.
houtex
05-09 Exterior Modifications
12
8/26/15 10:54 AM
