-   Repair and Service Help (https://themustangsource.com/forums/f804/)
-   -   Water running inside the door? (https://themustangsource.com/forums/f804/water-running-inside-door-549737/)
AlloyPony Mar 6, 2023 09:24 AM
Went through the automatic car wash this morning and noticed that it sounded like there was a waterfall going on inside the passenger door. Didn't hear it in the driver's door. Didn't see any water come inside the car. I noticed that the drivers door has open holes at the bottom. But on the passenger side these same holes are covered with plastic plugs. Is that normal?
https://cimg2.ibsrv.net/gimg/themust...46f121221f.jpg
05stangkc Mar 6, 2023 11:08 AM
Why?
https://www.cars.com/articles/why-do...1420680643430/
While You Are At It Check the Cabin Filter Drain!
https://lmr.com/products/s197-mustan...water-leak-fix
KC
m05fastbackGT Mar 6, 2023 03:43 PM
Especially when exposed to leaves/water build-up for prolonged periods of time while left parked outdoors... Thankfully, I don't experience these issues due to having a garage for always keeping the Mustang inside when, not in use... Therefore, none of my drain plugs have ever clogged up as a direct result...
AlloyPony Mar 7, 2023 05:18 AM
Thanks I pulled the plugs on the side that still had them. Will hose out any debris upon the next car wash.
m05fastbackGT Mar 7, 2023 03:16 PM
Pulling out the drain plugs and removing all debris should most definitely resolve the water build-up issues from within the doors!
