Texting Bug Identified in Sync v4.1.3
Old 1/20/13, 04:21 PM
  #101
JvKintheUSA's Avatar
subscribing...I have 4.13 on my '13 Shelby
Old 1/21/13, 09:13 AM
  #102
Zathu's Avatar
Here's some relief for those of us with recent Samsung Galaxy phones (root required). I've pre-patched these MAP profile APKs to be swapped out with the stock ones. They'll send the bMessage to SYNC out of spec to align with what SYNC reads so that the sender is correct. To install, browse to /system/app in ES File Manager and rename BluetoothMap.apk and BluetoothMap.odex (if present) to BluetoothMap.apk.backup and BluetoothMap.odex.backup. Cut and paste this APK. Long press the file, go to properties, and set permissions. Check the "read" permission for group and everyone so that it's "rw-r--r--". Reboot, unpair from SYNC, re-pair to SYNC.
Galaxy S3: https://dl.dropbox.com/u/50213/andro...uetoothMap.apk
Galaxy Note 2: https://dl.dropbox.com/u/50213/andro...uetoothMap.apk
*These were build from the AT&T versions of 4.1.1. They should work across all carriers. I haven't done a diff but I suspect that they're actually the same. The Note 2 APK was also reported to work on a Galaxy S2.
Old 1/22/13, 04:05 PM
  #103
MOTM Committee Member
stangfoeva's Avatar
Why don't you work for the Sync team? LOL.
You've done a great service to everyone for helping correct the issue. Thank you sir
Old 1/22/13, 04:21 PM
  #104
denlem's Avatar
But that doesn't help everyone! Only good if you're rooted and have the listed Samsung phones, and only confirmed on ATT. You may even need an unlocked boot loader
Old 1/22/13, 04:23 PM
  #105
stangfoeva's Avatar
True, but it's more than Ford has done LOL
Old 1/31/13, 12:23 PM
  #106
Twitch's Avatar
Thanks Zathu. Works perfectly for SGS 3.
A couple of notes 1) didn't work on 4.0.4 Att android build for me so you need to upgrade to stock 4.1.1 rom.
2) those unfamiliar with ES Explorer, to rename and move apk, first time in you need to goto Root Settings and check Root Explorer and Mount File System as writable boxes. Then you can copy and change permissions. Make sure you undo these checks when done so you don't accidently delete something from system folder unless you really mean to. I would guess most of you would not want to always maintain root access to these dirs.
Old 3/4/13, 02:41 PM
  #107
nebraskachers's Avatar
Well after having my Mustang for a year now not one update to solve the Text Messaging problem. I just got off the phone with Ford Sync customer service and they don't know anything about the problem we have been describing even though I've called numerous times about it for a year.
She stated I had the current version which is 4.1.3, even though now the 2014 Mustangs have version 4.1.4.t
I am now going to give up on this since Ford isn't listening to me or anyone else on this matter just their wallets.
I have called, emailed and chatted to Ford about this for a year now and nothing, they even state over and over again that they've never heard of this problem but yet we have a member on this forum who works for FORD that let them know and still nothing.
Ford you have really let me and others down and you should be ashamed of yourselves. We give you our hard earned money and even if you can't fix the problem (which I highly doubt) you could at least acknowledge the problem.
Thanks for nothing. I'll think twice about buying from you again.
Just a quick note, thank you to the people on this forum who are willing to find a work around solution to this problem. It is greatly appreciated.
Old 3/4/13, 04:12 PM
  #108
Zathu's Avatar
Fascinating.. Has anyone tried MAP on a 2014 Mustang?
I'm starting to feel the same way. On the other hand, who has done it better than Ford? Ford has the best features on paper, but the execution is sloppy. In what I've seen, the other manufacturers don't have nearly as much on paper, so the more basic features inherently just work because they're not really breaking any new grounds. As much as I like to see the built-in car tech advance, to meet the expectations set by our other devices we need someone other than a car manufacturer to back the development. If aftermarket stuff could touch the integration that SYNC has I'd be sold.
You're welcome! Thank you for pushing Ford on this through their official channels. Do you have a rooted Android phone that you were able to apply the workaround to?
Old 3/4/13, 06:04 PM
  #109
Ill admit that I love the car and the features if they all worked.
No I don't have a rooted phone, I'm just not into doing that. It is a Samsung Galaxy S3 with Sprint. When I get a chance I will try it on a 2014 Mustang.
Old 3/6/13, 02:04 AM
  #110
denlem's Avatar
Waiting for FordIVTeam's response to this, although I have the feeling that it will be her usual scripted response...
Old 3/6/13, 02:09 PM
  #111
Zathu's Avatar
The social FordIVTeam representation has done all it can do for us, this isn't really what that mechanism is designed for. It's great to have resources like that around for the right questions. IMO the blame for something like this can only go to Ford's management for not properly funding and executing effective software maintenance.
Old 3/7/13, 02:01 AM
  #112
denlem's Avatar
I'm done with this and moving on.
Old 3/7/13, 11:56 AM
  #113
tom281's Avatar
Denlem, some of your comments are unnecessary. I understand that you're frustrated and have been hoping for an update from the Ford team but apparently the few people in this thread that are upset with the problem aren't enough to justify it being corrected. Right or wrong, either way you don't need to make comments that are demeaning or insulting to the Ford team, so I edited your post.
I also am closing this thread until a Ford team member PMs me with an update, at which time I will gladly open it back up.
Old 10/2/13, 01:15 PM
  #114
tom281's Avatar
Open for posting! Please keep things civil.
Old 10/2/13, 03:33 PM
  #115
Zathu's Avatar
Good news! Ford has fixed the bug. I have attached an official technical service bulletin that confirms a fix for "Incorrect caller ID displayed for text messages", among other things.
The update was not available for me on syncmyride.com, so I had my dealer install it. I found the following version numbers to change:
OLD VERSION (4.1.3)
Auto Version Number
EC02345.8.10349_sp0.
FPN Number
DR3T-14D544-AD
NEW VERSION (4.2.1.4)
Auto Version Number
ED11545.8.10349_sp0.
FPN Number
DR3T-14D544-AE
I also now have a description of 4.2.1.4 on the syncmyride website:
DR3T-14D544-AE
This new software will provide the following enhancements to your current SYNC® system:
- Updated Bluetooth device connectivity
- Improved system stability
- Improved media player functionality
- Enhanced voice recognition capabilities
- Optimized for use with Apple iOS 6 for incoming text messaging
This update includes improvements from all previous SYNC updates such as flattened phone grammar, improvements in device indexing, text messaging capabilities with the implementation of message access profile (MAP), and more. For additional information on previous updates, visit SYNCmyride.com.
Please Read: This update may take up to 20 minutes to complete. About 1 to 3 minutes after you begin the installation, you will hear an Installation Complete message. DO NOT REMOVE YOUR USB DRIVE OR TURN OFF YOUR VEHICLE. You must wait up to an additional 20 minutes until you receive a second Installation Complete message before removing your USB drive. During this interval, while the update is loading, SYNC® will not recognize your mobile phone or media device. Be sure your vehicle's engine is running (not in Accessory mode) throughout the entire installation process. Although your vehicle must be in Park when you initiate the installation process, once the download process has begun, you may drive your vehicle.
Show your dealer the attached bulletin to get the update.
Finally!
File Type: pdf
Old 10/3/13, 06:29 PM
  #116
12GTCS's Avatar
My sync site says I have 4.0.2 and says its up to date. Can I install this new update or is it just for newer cars? Thanks!
Old 10/3/13, 08:28 PM
  #117
Zathu's Avatar
The TSB I posted is for 2012-2014 Mustangs, so I'd think the dealership could get you this update too.
Old 10/3/13, 08:43 PM
  #118
12GTCS's Avatar
Sweet, thanks for the info!
junkman9096
'10-14 Interior and Audio
5/12/16 12:43 AM
yabutt
10/23/15 01:05 PM
PonyMuscletang13
9/26/15 02:33 PM
Steve@CJPP
9/24/15 06:58 PM
Steve@CJPP
9/3/15 10:43 AM
Quick Reply: Texting Bug Identified in Sync v4.1.3
