starter keeps on cranking
Not sure if this is what you are experienceing...I will kepp looking.
https://themustangsource.com/f726/lo...-times-485729/
I've had this happen a few times now. Turn the key and release, and the car goes wild cranking and cranking until it finally fires up. It seems like a really long time, howerver it probably only does this for a few seconds. But still longer than normal.
At times, it probably cranked itself over more than 10 times before it fired up. Dealer knows, but hasn't done anything about it yet.
Originally Posted by cdynaco
Would putting in a Start Button defeat this stupid feature?
I'm referring to the auto start or one touch start feature of the '11's...
Stick the key into the ignition, turn it to the "start" position, once the starter begins to run, let off the key. The computer will take over and continue to turn the starter until the car starts.
So the fault isn't in the switch -- it's perfectly normal IF your car doesn't fire up immediately. The question is, "why didn't your car fire up right away?" not "why is my starter running on?"
But it did add the one touch. I just think it's a silly feature that adds something totally needless that can go wrong. And I think that's the issue here. I could be wrong.
To simply say that "they're all drive by wire" is akin to looking at a 1965 Mustang and a 2008 Mustang and saying "well, they all have sparkplugs".
Don't take it personally. I have no idea what you do in the "Oregon mountains" but I can tell you from 23 years inside "a Ford Manufacturing plant" that with every generation of powertains come with its own "advancements" and there are substantial changes when you are comparing a 2004 and a 2010 powertrain control system.
