Rear Brake Squeal/Squeak (BBP) 5.0
Old Aug 5, 2011 | 08:04 AM
99mstng's Avatar
So I just left the dealer and all is well now. They replaced my rear pads due to a very annoying squeak that developed at about 500 miles (1,4xx now). It would make noise while driving until I hit the brakes and got pretty **** loud.
Anyway for anyone interested in the rear pad part # for the Brembo GT's it's CR3Z-2200-A. FordParts.com doesn't list the part # (just says 2200) and it's shown as a Guinuine Ford Part vs. a Motorcraft part. MSRP is about $144 vs. $66 for the factory GT or Base.
Hopefully there will be no squeal after break in on this set!
Old Aug 8, 2011 | 10:55 AM
jlmounce's Avatar
I've got the same thing. However you have to attribute this to the type of pad. I know on the v6 performance package Ford specifically states they use Performance Friction pads. I'm assuming it's the same compound used on the brembo GT's. Performance pads simply make noise.
I'll probably swap mine out for a Hawk or Carbotech pad.
Old Aug 8, 2011 | 10:21 PM
99mstng's Avatar
This wasn't the squeal when coming to a stop this was a sound that radiated off the cars next to me while passing and was audible when inside the car with the windows up. It was very annoying and it went away when you applied the brakes.
Old Dec 15, 2011 | 09:28 AM
99mstng's Avatar
Noise came back . . . it's almost like an intermittent tic or click that sounds metal on metal and only from the right rear. When I press the brake just slightly or pull the e-brake it goes right away. Gets a little louder too when I start to accelerate.
Dealer said they were going to try to braze the pads a little this time to see if that would make it go away, cars already in storage though so nothing till next year.
Has anyone experienced this or have any thoughts?
Old Dec 15, 2011 | 09:32 AM
99mstng's Avatar
Noise was probably gone for about 500-1,000 miles after the first pad change and has been back now for about 1,000. I've tried to re bed the brakes at least a couple times with no real change.
Old Dec 16, 2011 | 12:39 PM
FordService's Avatar
Hi 99mstng,
I’d like to escalate this for you when you bring it back out. When the time comes, please PM me with your VIN, dealer, mileage, and contact info so I can help.
Deysha
Old Dec 17, 2011 | 01:12 PM
99mstng's Avatar
Thanks, Deysha. I'll let you know . . . gonna be a few months
Old Dec 19, 2011 | 09:20 AM
Ok, no problem!
Deysha
dbent15
Sep 5, 2015 12:15 PM
fredovega
Which is Better
Sep 3, 2015 07:20 PM
