O2 sensor issues
Hello,
I have a 2014 Mustang Gt with BBK long tube headers. It has been tuned and running great for over two years. Recently I started having issues with accelerating at about 2500 rpm. Sent a data log to the tuner and they said it was the o2 sensors. I switched the o2 sensors and it worked great for about a day or two and now same thing. Any suggestions? Thank you |
Knowing that your running long tube headers, are the 02 sensors disabled in the tune? if not, this could possibly be the reason for your acceleration issues...
Otherwise, I would make certain your 02 sensors that you switched are functioning properly... :dunno: |
Have You Tried Pulling Codes?
And if So is Your Reader Capable of Pulling B-Codes as Well as P-Codes? Also Consider an 02 Issue Could Also Be in Wiring To 02 Sensor and Also These Days Bad Parts Are Fairly Common Place. I Would Be Curious As To How The Plugs Looked as Well. Are They Fairly Fresh are Due For a Change? Was Any Kind of Work Period, Done Prior to Issue Surfacing? Kc |
| All times are GMT -6. The time now is 03:59 AM. |
