No crank, no start
No crank, no start
I have a 2013 Ford Mustang GT with a 2017 5.0 coyote swapped into it. The car would intermittently not start. I found a bypass in which if i turned the key and then shifted through the gears it would fire right up. About a month ago though I stopped at a gas station and no matter what i did it wouldn't start. I checked the starter relay and bypassed the clutch safety switch, no luck. Eventually had to pop/push start the car to get back home. Battery is fine and reads 13.7 volts. Car is too low to get a jack under it. Any advice?
@djoggerst
Welcome!
Not Much Personal Advice But The Bypass Switch Sounds Like a Work Around Due To Swap or Maybe a Quick Fix Due to Other Issues I Would Surmise. Need a Look At Starter Wiring For Sure.
I Use a Couple of 2x4's Under Front Wheels And Drive onto Before I Can Get a Jack Under Front of My Shelby.
I Found This One Thread!
https://themustangsource.com/forums/...-start-504184/
Also Listed Starting System Shop Manual Section & Wiring Diagram!
If You get into any PATS Issues Here are Some PDf's For That!
https://themustangsource.com/forums/...5/#post7079754
KC
Welcome!
KC
LVMustang05
Mar 4, 2012 10:54 PM
