-   Repair and Service Help (https://themustangsource.com/forums/f804/)
-   -   mustang Wrench light on, no speedometer, fuel light on (https://themustangsource.com/forums/f804/mustang-wrench-light-no-speedometer-fuel-light-549008/)
Stangproblems Dec 30, 2021 04:22 PM
I have a 2014 Mustang 6 cylinder that randomly, while driving, the wrench light comes on coupled with the speedometer reading zero, the gas warning light on (even when full), the message "---- miles to empty" on the dash and the transmission doesn't seem to want to shift.... It will stay in the same gear that it's in when it occurs. Any ideas? A good mechanic shop couldn't figure it out. they found a water leak dripping on a wiring harness in the engine compartment and cleaned that up but it didn't solve the problem.
Glenn Dec 30, 2021 05:52 PM
Welcome! Has the charging system been checked?
Ramirez68 Jan 8, 2025 02:03 PM
Did you find the solution? I have the same problem and I can't find what's wrong with it.
05stangkc Jan 8, 2025 02:18 PM
Welcome,
The Op Was a One Post One Wonder and is Unlikely To Reply.
The First Thing I Would Do is Check For Codes With a Reader Which Can Pull DTC as Well as Body Codes To Try & Narrow Down Possibilities. I would Be Looking At Sjb For Any Water Intrusion as Well. Seems To Be Par For The Course These Days For Electrical Issues on S-197 Platform.
If you Can Get Some Codes Reply With Them & I Will Post Ford Shop Manual Diag. Usually Better Info Than Just Generic Info The Reader Spits out!
This Thread on Earlier Model Can Shed Some Light if Unfamiliar With Issue.
https://themustangsource.com/forums/...26-7-a-550617/
KC
