Ford Mustang 2010 GT | Service Advanced Track
Old Dec 26, 2020 | 03:14 PM
ShortCut88's Avatar
Hello Guys,
Merry Xmas, wishing you all the best!
I reaching with a help request.
I have the the 2010 S197 GT the track pack.
I received it with ABS, Traction Off, and Traction lights constantly on.
I scanned the car and received C1958 code - dynamic stability control valve fl circuit fault.
As far as I know it was scanned with Launch.
I disconnected the module and sent it for repair.
I understand that it was opened, some pins reconnected and sealed back.
I received it back and reattached to the brake pump.
I downloaded FORScan now hoping that can erase code and problem solved.
But when I scan the car now I receive with this app P1000-FF.
Did anyone had similar experience?
Any hints how to solve it?
I will search again someone with Launch in order to delete the code with it.
I was surprised that FORScan did not do the job.
Here is the video with the dash and the FORScan scans -
And some images on the parts.
Old Dec 26, 2020 | 03:36 PM
Bert's Avatar
I think you might have come to the right place . . .
https://themustangsource.com/forums/...solved-546958/
but not sure if your issue might be different
welcome to the forum!
PS -- the "search" feature is your friend!
Old Dec 26, 2020 | 03:50 PM
ShortCut88's Avatar
Thank you Bert!
I checked this post but for some reason I underestimated it.
May be because if the error code I receive is correct it’s seams that should be the wire of front left wheel.
And as far I can understand the post it looks it’s the rear left wheel sensor.
But it have to be checked for what’s it word.
Thanks again
Old Dec 26, 2020 | 06:51 PM
houtex's Avatar
P1000 means the car's not been driven enough to set the readiness states of various checks/inspections it does to the car. It's only worthy of attention when you have a problem you can't get a code for, such as emissions, because the car's not run long enough for the emissions to have been properly checked by the PCM. Which simply means you got to drive the car more to get it to run those tests.
Keep driving it, that code will go away. You can safely ignore it.
Welcome to the forums! Hope that helps!
More info here:
phiggs54
2012-2013 BOSS 302
Nov 4, 2011 06:24 PM
Evil_Capri
Motorsports
Oct 9, 2010 11:52 PM
Ltngdrvr
Jun 27, 2010 09:58 AM
Zastava_101
Motorsports
Oct 23, 2009 08:00 AM
