-   Repair and Service Help (https://themustangsource.com/forums/f804/)
-   -   Check engine light (https://themustangsource.com/forums/f804/check-engine-light-541257/)
Austinoblas Apr 27, 2016 05:31 PM
Check engine light
Sometimes my check engine light will come on for no apparent reason then go off after a couple days, why would this be? When I had to codes pulled nothing came up. I drive a 2012 mustang 5.0, with bbk cold air, and flow master exhaust. Admittedly I do drive a little crazy. But what mustang owner doesn't?
SpectreH Apr 27, 2016 08:03 PM
Gas filler door not sealing well, causing an evap leak?
Austinoblas Apr 27, 2016 08:13 PM
That's what I figured, I'll check it in the morning. The **** light just causes so much stress even when I know it will go off in a day or so
SpectreH Apr 27, 2016 08:15 PM
Check for codes while the light is on, if you haven't already done that.
