Originally Posted by DarrenGT
(Post 6751042)
"Replace parts ordered FDIM and do PMI"
no idea what exactly was replaced but the new facing had a peal away decal on it, like brand new. My bluetooth and phone were still in sync so it's highly unlikely they replaced the entire radio unit. You could tell where the peel away decal had been on my new screen. They took it off after installation. From what I have learned is that the FDIM is not the radio itself but the screen but I'm not clear on what screen it is. The one on the radio itself or the one mounted into the front cover panel that looks damaged on our cars. My work order says they inspect, verify concern, removed and replace radio unit as needed, retest. I'm going to assume that means I got a new radio. My radio presets were correct from what they were before so I guess they have some way of retaining that info or maybe they just wrote them down and reinstalled them. I think it is interesting that some people are supposedly getting new radios as well as the new front cover and some people are just getting the front cover. Wayne |
I'm glad to see I'm not the only one with the radio surface delamination issue. About 3 months ago a small spot appeared and finally took over my entire radio surface. It was almost impossible to see with the light shining on it. I knew I had never cleaned the surface with anything so I had no idea what it could be. I was in the shop getting an oil change and mentioned it to them and they told me they get about 1 a month of these happening on the Escapes and only had it happen on a few Mustangs. They ordered the module for me and replaced it today in about 15 minutes free under warranty. They said they're not sure what causes it but think it's heating/cooling or the sun.
http://hostthenpost.org/uploads/f0d6...b3ccd06d34.jpg |
Originally Posted by smiley
(Post 6756730)
(Post 6756730)
Deysha |
They are changing mine today too....
Originally Posted by alfaromeo
(Post 6747648)
my screen does the same thing as well. I thought it was kind of frost effect since it is bitter cold recently and my windshield does get frost inside every morning. Until I go across this post, I can't believe it is defect and need be fixed.
Thanks everyone, I will let my dealer work on this next time I dropping by. The replaced part is only screen itself, radio set is kept untouched. |
(Post 6769704)
Update: couple days ago, I brought my car to dealer have them check it out and confirmed the issue. Dealer ordered part and replaced the screen two days later. Dealer also updates the sync and brought me new "mustang" message and additional vertical lines. Very happy.
No it will not go away it is leaking get it replaced as I did
So are brand new '14s coming out of the factory the last couple months still coming with this old problematic screen or are they coming with updated screens and the sync updates with the lines and Mustang text at startup?
When I got mine fixed back in January on my base model car that does not have sync, I got the line and the "mustang" text at startup. I don't know if the new 14's have the updated screens. They should since the special service message addressing this problem came out in October of 2013.
Wayne |
My car was built 3/17/14 and does NOT have this updated unit. Most likely I'd guess that means the update is a new headunit/hardware replacement update rather than just a software update.
Originally Posted by puma1552
(Post 6780243)
Here is what the SSM says on this issue. Since my car does not have sync, that is not the reason I now have the blue line and the "mustang" message after my repair.
I'm also not totally sure what was replaced during my repair other than the screen in the "front control interface module" as the SSM describes it is new. I'm not sure if the FDIM is the actual screen on the radio itself or it's the screen in the "front control interface module". That is where I'm confused. My repair order says "replace radio" so I'm assuming the entire radio is new but I could be wrong. OASIS SPECIAL SERVICE MESSAGE NUMBER: 44226 MESSAGE TITLE: Multi Vehicle Line - Front Display Interface Module (FDIM) Display Distortion APPLICABLE VEHICLES : 2011 CAR : 00122 FOCUS 2012 TRUCK : 00189 FLEX 2012 CAR : 00170 FUSION 2012 CAR : 00117 TAURUS 2012 - 2013 TRUCK : 00029 F-SERIES LD 2012 - 2014 CAR : 00071 MUSTANG 2011 TRUCK : 00163 MARINER 2011 - 2012 TRUCK : 00130 ESCAPE 2011 CAR : AU FOCUS (CW170) - N.A. 2011 TRUCK : M7 ESCAPE/TRIBUTE/MARINER-LHD 2012 CAR : DE FUSION/MILAN/MKZ (ZEPHYR) 2012 CAR : PH TAURUS 2011 - 2012 TRUCK : M7 ESCAPE/TRIBUTE/MARINER-LHD 2012 - 2013 TRUCK : F6 F150/LINCOLN MARK LT 2012 - 2014 CAR : ZF MUSTANG (S197) OASIS MESSAGE : Some 2011 Focus, Mariner; 2011-2012 Escape; 2012 Flex, Fusion, Taurus; 2012-2013 F150; 2012-2014 Mustang vehicles may have a distorted FDIM display often described as being delaminated, frosted, cloudy, hazy, faded, and/or foggy. FDIM service parts have been improved and are now available. Base Part Number 10D885. Please use available labor times to correct the condition. APPLICABLE SYMPTOM CODES : 1***** Comfort & Entertainment 112*** Comfort & Entertainment > Audio 1126** Comfort & Entertainment > Audio > Display/Multifun 112636 Comfort & Entertainment > Audio > Display/Multifun 112638 Comfort & Entertainment > Audio > Display/Multifun 200000 ELECTRICALmp; Entertainment > Audio > Display/Multifun 207000 ELECTRICAL ENTERTAINMENT SYSTEMS Audio > Display/Multifun The FDIM is not the radio, it is the actual screen, stands for Front Display Interface Module. The radio unit itself is actually called an Audio Control Module. The part with the buttons is called the Front Control Interface module. We also have Accessory Protocol Interface Modules (sync) and Human Machine Interface Modules. |
Deysha...this thread is old...but I am having this issue with my '14 Mustang. Are you still able to escalate this issue?
Originally Posted by rkuzelka
(Post 6797173)
Deysha |
Im also having this issue with my new mustang. I noticed it about a month after I had the car, and I baby it so I know I didnt cause it. I went to my local dealer and they told me it would not be covered and that I would have to pay to repair it.
Originally Posted by grabbermustang
(Post 6802121)
This is a recurring problem with this defect because it fails in a way that looks like it was damaged. |
(Post 6802121)
Originally Posted by mfc133
(Post 6802130)
Walk in with a printed copy of the SSM from 3 posts above, they won't be able to argue with that. If they still give you trouble Deysha can help you out.
This is a recurring problem with this defect because it fails in a way that looks like it was damaged. Deysha |
I had been searching for months..what was going on with my radio screen. I have this exact same problem, my car is used re-certified from Ford so I guess I'll call my dealer too.
Are you guys getting this fixed under warranty? My dealer told me that I put the scratches in the screen and won't fix it. Which is total BS. It was cloudy, I took it in and they "detailed" the screen and put all these scratches in. Has anyone replaced the screen? I'm thinking about doing it.
| All times are GMT -6. The time now is 02:01 AM. |
