Any updates?
Originally Posted by cholmes1
(Post 7040145)
Any updates?
13-14 left side switch values: On/off - is grounded = .5 ohms or less Cancel/resume = 620-622 ohms set - = 155 ohm Set + = 353 ohms 5 way button: Ok = 1350 ohms / 2.10 kohms up = 366 ohms Down = 890 ohms Back = grounded 0/.5 ohms Forward = 633 ohms |
Forgive my ignorance here but wouldn't you be able to repin the connector on the steering wheel side to get it to match up to where they were originally going? And then add the resistor to that, if needed?
Originally Posted by Donnie Simms
(Post 7041254)
If you can tell me what resistors I would need that would help but I think I'm the only one that's swapped or trying to make the controls work. Ill post up what the S550 switches are reading later on today or tomorrow. |
Yeah, thats what my friend was telling me, everything goes through the controller first and it translates it to the car, he said it would be very tough to get the cruise to work. That is my mine concern is the cruise.
Check out the thread in this section about adding the LED cluster. We had to modify the switches to get cruise to work by changing the resistors. Might help.
Would the steering wheel swap be easier if you also swap the sync module from the 15+? Not sure if that can even be done.
Cruise signals need to be recognized by the PCM and the cluster. Sync wouldn't do anything.
It has been about a month since the last check-in...any updates or changes?
(Post 7042461)
Sorry nothing new to add. Been busy with work and getting everything ready for the new baby to arrive. Im hopeing I get to play around with it next month since I'll be taking at least a week off but then again it all depends on the kids lol. |
Sorry everyone its not the update you were waiting for but this is gonna be on hold for awhile. Unfortunately my cars clutch, hopefully just the throw out bearing since I would not engage in any gear once the clutch pedal was depressed, went out while we were going to the hospital as baby 2 wanted to come out already. That needs fixing 😪 hopefully by the end of the year if not maybe someone else can do it for now.
Congratulations on the baby. Hopefully, everyone is healthy and happy
Originally Posted by RRS197
(Post 7032470)
Small update:
got the column and it fits!! https://cimg5.ibsrv.net/gimg/themust...8e443a1ddf.jpg https://cimg6.ibsrv.net/gimg/themust...8787f4e9ac.jpg https://cimg9.ibsrv.net/gimg/themust...b1a28e2593.jpg |
Originally Posted by bogdi1988
(Post 7043509)
Were you able to get the switches on the column (ex: blinker, high beam, wipers) to work with the old 10-14 wiring?
Unfortunately not at this time as the s197 has more wires then the s550. |
(Post 7043510)
https://docs.google.com/spreadsheets...it?usp=sharing |
Heres the s550 Schematic:
https://cimg3.ibsrv.net/gimg/themust...8cd24b241.jpeg |
I started working on the wiring itself. I got the horn wiring figured out. The backlight is good to go as well for all buttons.
I am having a bit of a hard time figuring out each of the button clusters. It seems that there are up to 2 channels per button clusters and a ground for the buttons. I am not able to get the resistance of the buttons when they are pressed. It shows up as the circuit is not closed. Any inputs? |
(Post 7045299)
I am having a bit of a hard time figuring out each of the button clusters. It seems that there are up to 2 channels per button clusters and a ground for the buttons. I am not able to get the resistance of the buttons when they are pressed. It shows up as the circuit is not closed. Any inputs? Right on. for the buttons the top right is the easiest to far if you look on the first page you would have to just move some of the connections around as the buttons are switched. the forward and back is ok just the up down and media buttons are switched around like up is volume down, middle is volume up and down is media. im stuck on the rest unfortunately and haven't done anything as of late size my boy came out in July. |
(Post 7045305)
Great news! I got the steering wheel connected and it is working!
Some lessons learned and things to do leftover: - left buttons and right buttons seem to have a very close resistive value so both sides do the same thing. They will need to go on a different SWC channel instead of how the harness has them joined to the blue line OR add a resistor in front of the left buttons to change the value slightly - cruise control buttons don't work just yet. I have a plan for those that involves the old button boards from an 05-09 connected directly to each button of the CC side - phone buttons work, kinda. Seems like phone up and phone down have the same value as the other two (channel 3) so I will need to add another resistor there as well - airbag connectors - I took apart the connectors from a newer clock spring, and was able to use the wiring from 05-09 by just getting them in the new connectors. No need to cut wires etc - horn, works as well - no need to hack the button boards like the posts above Current wiring setup: - blue line (channel 1) goes to SWC1 - orange, green and brown go to SWC2 - black, red and purple go to the grown wire on the clockspring (together with the black wire from horn wires) - white wire from horn goes to the horn wire of clockspring - yellow goes to backlight on clockspring I need to order a few resistors and I should have all media buttons working soon! In the meantime... enjoy the picture below! :) This will go VERY well with the 2014 dashboard that I have in progress with a custom center cluster that uses the 05-09 AC controls, 05-09 gauges with a 2014 lens and indicators and 2014 headlight switches. THAT will be an even more fun of a project! https://cimg4.ibsrv.net/gimg/themust...445010e410.jpg |
| All times are GMT -6. The time now is 03:21 AM. |
