-   '10-14 Interior and Audio (https://themustangsource.com/forums/f803/)
-   -   Retrofitting the 4.2 LCD Track Apps cluster (https://themustangsource.com/forums/f803/retrofitting-4-2-lcd-track-apps-cluster-529167/)
falconflyr6 Aug 28, 2024 07:53 PM
‘13/‘14 Dash Harness works
All,
Just a heads up for those still doing this to their cars - I added the ‘13/‘14 cluster to my ‘11, PATS relearn, new steering wheel button, wiring, all that and it worked great for a bit. Fast forward a year and I am forced to move to Las Vegas in the summer. Button slowly stops working, thought it probably melted but no, everything looked fine. Fast forward another year, and many, many times redoing the wiring and I just cannot for the life of me get it to work again and I don’t know why. A week ago I finally just said f*ck it, bought a ‘14 wheel off of eBay and ripped the harness out and installed in my Boss 302 wheel, bought a new ‘14 Main Dash Harness (same features for my ‘11 when I did the Nav install…but ‘14) and was resigned to “if this doesn’t work, guess I’m getting a new pony a year earlier than I wanted.”
It works. Obviously a few things won’t like sound from the radio - easy solve since that’s just needing a ‘13/‘14 ACM with the amp built in. The connectors to the driver’s kick panel amps aren’t the same, and the OBDII port doesn’t click into place…all of these things really easy, minor fixes. But a solid, easy fix that does not require wiring for electrically-challenged folks like myself. Button and cluster are working well and I finally am not wanting to take a sledgehammer to them!
05stangkc Aug 29, 2024 04:18 AM
Thanks For Coming In an Updating!
:nice:
KC
ebt5.0 Jan 25, 2025 01:04 PM
Gt500
So if I have a 2013 track pack that already has the lcd and track apps can I swap a 13-14 gt500 cluster in also if I could would I get launch control like the gt500?
05stangkc Feb 7, 2025 07:05 PM
This Info Maybe Helpful To Those Needing To Reprogram Modules!
https://themustangsource.com/forums/...9/#post7090848
KC
05stangkc Apr 9, 2025 07:55 AM
Found This!
KC
Mitka Oct 20, 2025 02:28 PM
Originally Posted by Mitka (Post 7085769)
Another issue I came across when installing 2013 premium cluster into 2010 premium car is that I have OIL CHANGE REQUIRED message every time I start the car. Oil life reset doesn't help.
The thing is that I did not put any additional wires from light switch to cluster (C220), I have connected light switch directly to clockspring switch on the wheel from the cluster side. Can it be the reason? Please help
Cruise control does not work also.
Oil change required annoying message
Solved. IPC module, line 720-01-01: E798 6F61 78 , Oil life monitor is now completely off. No Oil change required message!
