-   '10-14 Interior and Audio (https://themustangsource.com/forums/f803/)
-   -   Question about adding a back up camera to oem nav (https://themustangsource.com/forums/f803/question-about-adding-back-up-camera-oem-nav-548205/)
Anthony Murdock Jan 12, 2021 09:42 AM
So every backup camera I'm seeing has the yellow rca cam for video, how do I get that to go to the wires for back up cam input, do I just cut the yellow rca? And use the wires from the cut?
konasnake Feb 5, 2021 08:04 PM
I purchased a rca cable with female plugs and cut it. Connected it to the camera wires at the plug in the kick panel, then connect the camera rca to that. Works great and has the delay feature of factory camera
cholmes1 Feb 15, 2021 11:12 AM
You will need some type of processor to connect the RCA camera signal to something that can be read and recognized by the OEM navigation. I chose, what I feel, is the most simple path. Hopefully it helps with your project
Info Here: https://trackmustangsonline.com/thre...30/post-236081
