help with replacing 2012 sub amp
I just purchased a 2012 with the shaker 500 system and nav. I ordered a couple shelby kicker speakers as they are plug and play. I'm aware i need to change the amp as well.
I'm looking for a fairly plug and play solution. I did some searching online, and several posts/sites mentioned using a sony small amp. But it's not plug and play. Should i get a different amp? or just find the right harness? The amp is only for the door subs. ideally, i hope to get 2 harnesses for this to work --- 1 from head unit to amp, 1 from amp to door speakers. Thanks! |
Originally Posted by mango14
(Post 7027569)
I'm looking for a fairly plug and play solution. I did some searching online, and several posts/sites mentioned using a sony small amp. But it's not plug and play. Should i get a different amp? or just find the right harness? The amp is only for the door subs. ideally, i hope to get 2 harnesses for this to work --- 1 from head unit to amp, 1 from amp to door speakers. Thanks! did you ever find a solution. I would like to know also. |
| All times are GMT -6. The time now is 06:15 AM. |
