-   '10-14 Interior and Audio (https://themustangsource.com/forums/f803/)
-   -   Engineering mode with digital speedo (https://themustangsource.com/forums/f803/engineering-mode-digital-speedo-518839/)
Snoopy49 Feb 20, 2013 04:15 PM
It doesn't seem to work on a 2013 GT500.
Midlife Crisis GT Feb 20, 2013 04:42 PM
I agree when 1st got the car this made no since that the speedo was not displayed in the center. I wish Ford would do some kind of update to allow this to be an option without having to go into the system to program it.:banghead:
steve03gt Feb 20, 2013 04:43 PM
There were more than a couple things I found off that a Focus has yet a higher optioned Mustang or F150 didn't have for no obvious reason.
Originally Posted by cfraser (Post 6558499)
Yup, display of cruise control speed is another thing I couldn't figger, considering all the "infrastructure" is already there.
Re memory mode: I have that enabled, but it still requires several button pushes to get back to the same gauge I was displaying when I turned off the ignition. Minor I know, obviously I can live with it. Bottom line is the capabilities of the existing system are not fully utilized, and it's unnecessarily "awkward" in some operations IMO. ['13 V6]
Since I'm whinging: let's also put more space to the right of the "right arrow" in the "OK cluster". I can barely get a finger in there, and I'm small. Forget a thumb, which that button naturally wants to be pushed by if you're holding the wheel.
kyle2008 Feb 20, 2013 05:21 PM
Can this be done in an 08 ?
geh4 Feb 20, 2013 06:29 PM
Does anyone know If you can do this in an 06?
Banjostang Feb 20, 2013 07:52 PM
Here's a fix for you.
1. Get a small post-it note
2. Write this phrase on it: "i'm in a GT500 going faster than everybody else"
3. Stick it on your speedo
Problem solved.
:nice:
wheelman Feb 21, 2013 03:09 AM
You tell us!
youngstang90 Feb 21, 2013 05:51 PM
So I tried this in my '12 premium.....nothing. Is there something I'm missing?
outtaphase Feb 22, 2013 05:36 PM
It does, I just used it today. One thing I noticed - some people say you can start the car while holding OK for some model years. This doesn't work on a '13 GT500, you have to press and hold OK, rotate the key to "on" (but do not start), and keep holding until engineering mode comes up. Then you can start it and it will stay in that mode.
JVasser Feb 23, 2013 01:29 AM
Same here, tried it tonight on my 2011 300A spec (Base GT) and got nothing...
youngstang90 Feb 23, 2013 07:08 AM
I tried every combination of buttons....nothing happens. (Info, setup, reset)
SwissGT Feb 23, 2013 07:19 AM
For pre-2013 cars, it should work as follows:
- Turn ignition OFF
- Press and hold "RESET" button
- Turn ignition to ON, or RUN
- "Engineering Test Mode" appears in the display
- Release "RESET" button
- Use "RESET" button to toggle through the items
Works in my 12 GT Premium.
youngstang90 Feb 23, 2013 04:07 PM
- Turn ignition OFF
Going outside right now to confirm. Will update shortly.
:update:
Doesn't work on mine. How long did you hold it for?
SwissGT Feb 23, 2013 04:28 PM
You need to hold Reset until "Engineering Test Mode" appears.
I'm not sure if this works on V6 models, however it would supreise me if it didnt.
jim010 Feb 23, 2013 07:48 PM
How long are you holding the button for?
youngstang90 Feb 23, 2013 08:37 PM
I held it for about 5 seconds, then my check engine light started flashing. So I let go. As soon as I started the car it turned off though.
FordService Feb 26, 2013 07:07 AM
Originally Posted by outtaphase (Post 6557959)
Just tried it on my '13 GT500, it works. Neat feature, thanks for sharing. Google wouldn't reveal a list of all the code meanings, anyone else have luck with that?
I did notice that most modern Fords have this feature. If you don't have OK on the steering wheel (e.g. '10 Mustang) use the reset button instead. Gonna try this on the wife's Escape.
Hi outtaphase,
This is a setting we have in place for our technicians to run tests and such when your vehicle is brought in for a concern. I see most of you would like this digital speedometer to be an option, make sure you provide us with your feedback at Ford Social.
Deysha
Rando Feb 26, 2013 09:41 AM
Why haven't the companies that make tuners started modding the LCD? Obviously if they're tapping into core electronics this won't be a problem.
jim010 Feb 26, 2013 10:14 AM
I'm still am having no luck with this in my 2012 GT
Overboost Feb 26, 2013 10:24 AM
For those of you with 2010-2012 cars, to get into the test mode:
-Hold "Setup" and "Reset" buttons under the headlamp switch
-Start vehicle
-Use the "Reset" button to cycle through the various functions
Mode will be active until the car is shut off.
