-   '10-14 Interior and Audio (https://themustangsource.com/forums/f803/)
-   -   Door panel insert removal? (https://themustangsource.com/forums/f803/door-panel-insert-removal-526483/)
numnutz Nov 19, 2013 01:57 PM
Can anyone tell me how to remove the door panel insert directly above the armrest on 2012 base convertible? Does it snap out, or will I have to remove the complete door panel? Thanks.
southcarolina12 Nov 19, 2013 02:28 PM
it looked to me like its molded to it when i had my door panel off last week.
numnutz Nov 19, 2013 05:59 PM
Thanks. I was hoping it would snap apart like the other plastic pieces. Thanks again.
zbrewha863 Nov 19, 2013 07:05 PM
It definitely comes off because I have seen it replaced, like on the MRT Mustang. Next time my door panels are off, I will check!
RubyRedMCA_Beast Nov 19, 2013 08:25 PM
It may be 'plastic welded' in or whatever it's called. Meaning you might have to cut/drill plastic to remove it. I don't know for sure.
Stevedotmil Nov 21, 2013 03:43 AM
I have been wondering this same ruins because I want to cover mine in suede instead of the pleather that it came with standard. So it will finally match my shift boot I made. I used ultra suede on the shift boot though so I might redo that as well. Shift boot is my build thread in case anyone was wondering.
ColSaulTigh Nov 21, 2013 07:20 AM
It's glued in place. Heat gun to the BACK side and some prying might remove it...
numnutz Nov 21, 2013 09:22 AM
Thanks for a definitive answer; sadly I ain't that brave. Thanks again. Can of SEM still looks like the solution.
