-   '10-14 Interior and Audio (https://themustangsource.com/forums/f803/)
-   -   Different OEM shift Knobs? (https://themustangsource.com/forums/f803/different-oem-shift-knobs-552320/)
Slonison Dec 25, 2025 11:55 AM
Hey guys, it's finally time to replace my OEM shift knob. I opted to go for OEM again. Oddly, the font has changed. This is a legit part that came in Ford packaging in a Ford box
Is there any documentation that this changed over time?
I know they changed the 2013 and 2014 cluster fonts so I'm wondering if this was a change at some point as well.
https://cimg6.ibsrv.net/gimg/themust...3d7528a502.jpg
https://cimg7.ibsrv.net/gimg/themust...e6c30f0198.jpg
https://cimg8.ibsrv.net/gimg/themust...d8c4239070.jpg
This is the link it was bought at
https://ebay.us/m/6Yp2fm
Yes I know eBay seller. I'm not disgruntled. More curious if there was a change over years?
If anyone 2010 to 2014 and still has the OEM shift knob. Would be great if you can check yours for me.
Steve
05stangkc Dec 25, 2025 01:45 PM
Two Different Styles Base & Deluxe on Ford Listings
Can't Always Get a Definitve Ford Parts Picture as Ford Sometimes Uses Similar But Not 100% Pic. I Could Not Find Where Either FORD Part Number Had Been Superceeded at Any Point. The B Knob Has a Silver Trim Ring Around Bottom! At Least in Parts giant Pics! Other Places Ring Shows on Some A's as Well! Now Ford Will Change Things From Time To Time But That Usually Warrants a Part Number Change Which I Found None!
https://www.fordpartsgiant.com/page_...&keywords=7213
Try Cataloging with your Vin! Using Vin Should Show Correct Number Even if Pics Don't Quite Jive. That is If Knob is Indeed Original And Has Not Been Replaced at Some Point.
Here are Lmr's & Parts Giant Pics!
Hope That Helps!
I Started Some More Searching and The More I Look The More I See Different Pics With Same Part Number!
So Similar But Not Exact That Nobody Bothers To Be Accurate!
KC
https://lmr.com/products/10-14-Musta...mponents#31031
https://www.fordpartsgiant.com/parts...tra2=&filter=()
https://cimg5.ibsrv.net/gimg/themust...b57fe77c53.jpg
br3z7213b
https://cimg6.ibsrv.net/gimg/themust...899c108fdc.jpg
br3z7213-a
