Different OEM shift Knobs?
Old Dec 25, 2025 | 11:55 AM
Slonison's Avatar
{Step by Step} The Tms Accessorizer
Different OEM shift *****?
Hey guys, it's finally time to replace my OEM shift ****. I opted to go for OEM again. Oddly, the font has changed. This is a legit part that came in Ford packaging in a Ford box
Is there any documentation that this changed over time?
I know they changed the 2013 and 2014 cluster fonts so I'm wondering if this was a change at some point as well.
This is the link it was bought at
https://ebay.us/m/6Yp2fm
Yes I know eBay seller. I'm not disgruntled. More curious if there was a change over years?
If anyone 2010 to 2014 and still has the OEM shift ****. Would be great if you can check yours for me.
Steve
Old Dec 25, 2025 | 01:45 PM
05stangkc's Avatar
Two Different Styles Base & Deluxe on Ford Listings
Can't Always Get a Definitve Ford Parts Picture as Ford Sometimes Uses Similar But Not 100% Pic. I Could Not Find Where Either FORD Part Number Had Been Superceeded at Any Point. The B **** Has a Silver Trim Ring Around Bottom! At Least in Parts giant Pics! Other Places Ring Shows on Some A's as Well! Now Ford Will Change Things From Time To Time But That Usually Warrants a Part Number Change Which I Found None!
https://www.fordpartsgiant.com/page_...&keywords=7213
Try Cataloging with your Vin! Using Vin Should Show Correct Number Even if Pics Don't Quite Jive. That is If **** is Indeed Original And Has Not Been Replaced at Some Point.
Here are Lmr's & Parts Giant Pics!
Hope That Helps!
I Started Some More Searching and The More I Look The More I See Different Pics With Same Part Number!
So Similar But Not Exact That Nobody Bothers To Be Accurate!
KC
https://lmr.com/products/10-14-Musta...mponents#31031
https://www.fordpartsgiant.com/parts...tra2=&filter=()
br3z7213b
br3z7213b
br3z7213-a
br3z7213-a
fizzlymauler
'10-14 Interior and Audio
Sep 15, 2012 06:06 PM
Halfadeck
Sep 8, 2012 05:39 AM
