Can the power outlets be set to turn on and off with car
I did it without cutting or splicing any wires. Pretty much like I said in my first post. I found the fuse which is in the engine compartment and wired a relay in place of the fuse and triggered it with a ignition on wire also from the fuse block so I have the 20 amps available but only when the ignition is on.
Could you tell what accessories fuse or relay you tapped off from to do this mod? What year/model is your vehicle that you did this on?
Mine is a 2006 Mustang.
Thanks so much for your help.
AMWill
Jul 20, 2015 08:40 AM
