Aftermarket amp install
I installed the factory nav system so I need to go with an aftermarket amp. From what I can tell the factory amp for the door subs is still used so I need to power the four speakers between the doors and rear deck. Can I use this PAC AOEM-FRD24 to splice into without hacking up my factory wiring? Or did anyone who wired in a aftermarket amp have any suggestions? Was headed to the stereo shop but 14" of snow on Friday brought that to a halt. Thanks.
Originally Posted by Grabber5.00
(Post 6955270)
The install on the factory nav wasn't hard. Just time consuming. It really is just plug and play though right up to this part. Why did you run new wires to your speakers? That is what I am hoping to avoid doing by using this PAC module.
I could have just spliced into the factory wiring but it was easier to run new wires.
Originally Posted by DJ2014
(Post 6955299)
This is exactly what I used. I installed an eq and amp to improve the sound. Also replaced all four speakers and ran new speaker wire. That was a pain getting it through to the door speakers. I left the door subs being powered by the oem amp. I would love to install the factory nav system. Was it an easy install?
I am apparently finding the amp install tougher than most. I used the pac module I listed above but I only got the right front and right rear speakers to get any sound. I tried switching those leads to the front left and rear and still no sound? Then I took out the RCA leads and wired it speaker level and just used the pac harness to splice into. Same results When I look at the wiring diagram it appears that the pac module is pinned correctly. Any one have any ideas what I am missing?
(Post 6956149)
I see there are holes above each channel that looks like you can adjust stuff. But I am not getting anything to the drivers side of the car. Did you have to adjust those to get your signal?
(Post 6956165)
Yeah. Fader and balance are set correctly. The other weird thing is that the outputs that do work don't match up to the fader and balance. I have both the front and rear right side going but it's like they are both running off the front signals. When I fade to the rear I have nothing. Like the RR is running off what should be Front left. Factory wiring diagram looks like what I have on the aftermarket harness should be matched up correctly though. I don't know what the hell I'm doing wrong.
If you swap the RCAs does the sound move to the other side?
I swapped the wire leads and the sound did not move over. I hacked the rca's off and direct wired it and switched the amp to speaker input and no change.
I thought that maybe the acm was bad but I should have sound when I switch the wires.
That's weird. :wonder:
Did you run new wires or just use the pac module?
(Post 6956185)
| All times are GMT -6. The time now is 03:33 AM. |
