-   '10-14 Interior and Audio (https://themustangsource.com/forums/f803/)
-   -   Adding the OEM nav (https://themustangsource.com/forums/f803/adding-oem-nav-516988/)
LEXiiON Mar 10, 2014 09:54 AM
According to the picture i posted above, it might be the GPS module.
LEXiION
zeroaviation Mar 10, 2014 09:58 AM
You are correct. That is the GPS module.
It will not be reused.
-Matt
LEXiiON Mar 10, 2014 10:11 AM
Ok. Got it. Looked at the wiring diagrams and they only show the GPS module without Navigation.
Thanks,
LEXiiON
jim010 Mar 10, 2014 10:41 AM
Matt is correct. You will not reuse the GPS module that was in your car. Take it out.
defiance772 Mar 10, 2014 11:18 AM
Cool Great thanks guys. Hey Jim how did you take out that climate control module from the center dash part. Do I have to push the clips in?
jim010 Mar 10, 2014 12:28 PM
Yes, those clip need to be carefully pushed in and then the module is pryed out.
defiance772 Mar 11, 2014 07:12 PM
1 Attachment(s)
Hey Jim and muskoka or anybody else I unbolted everything and me and my buddy are trying to remove the dash it's loose but something it's not budging I feel like were missing a bolt but don't know where it is what section of the service manual does it show where the bolts are located I been looking like crazy. I removed all the bolts circled.
Attachment 194360
Muskoka Mar 11, 2014 08:55 PM
Hi
Look under the drivers section and there is a bolt holding the door speaker amp. One bolt going to the left. You have circled it however it is often overlooked. In total there are 12 bolts to undo.
Muskoka Mar 11, 2014 08:58 PM
Hi
You have not circled the two bolts under the ACM by the shifter.
defiance772 Mar 12, 2014 12:08 AM
Hey Muskoka thanks for the help you were right those were the screws lol. Well dash is out but were confused about the Dual evaporater housing are we suppose to take the whole entire housing and switch and switch it with the single. We tried removing the whole single evaporator housing from the car but couldnt figure out how to remove it. Were stumped.
defiance772 Mar 12, 2014 12:22 AM
Hi Muskoka. After I remove the plenum which im guessing is the top part of the housing what do I do with the rest of the dual zone housing. So basically you keep the single zone housing with the dual zone plenum.
defiance772 Mar 12, 2014 10:04 AM
1 Attachment(s)
Heres a pic. Do I remove the top which is the red circled part away from the blue circled part on the dual evaporator. and then put that on the single evaporator bottom part of the single evaporator. Basically what i'm trying to find out if the evaporator dual or single is 2 pieces put together in the picture
Attachment 194356
Trevor08gt Mar 12, 2014 10:37 AM
1 Attachment(s)
This is what I have. Do you guys think I'm missing anything?
jim010 Mar 12, 2014 11:46 AM
Looks like you have everything. Hard to tell if you have all the harnesses.
What about the amp?
Trevor08gt Mar 12, 2014 12:19 PM
What about the amp?
I'm going to contact him right now to see if he has the amp or not. I need the amp, amp bracket and the pigtail right?
jim010 Mar 12, 2014 12:37 PM
Yes.
You also need the right side steering wheel switch to get the phone button to work. Part number I added to the post at the beginning of the thread.
Muskoka Mar 12, 2014 01:06 PM
Hi Defiance
In your pic. Remove the parts circled in Blue. that will give you access to the additional screws to remove the plenum from the housing.
Yes you only replace the plenum and leave the rest of the single zone housing in place.
There is one screw on the underside of the housing that is hidden from view in the evaporator housing in the dash. If you have removed the plenum from the replacement evaporator housing then you know how to install the new one. Just be careful not to damage the fins of the AC evaporator and the Heater core when you remove and replace the plenum.
Hope that this helps.
Muskoka Mar 12, 2014 01:08 PM
The red area is what you are replacing only. You leave the blue area in the car.
defiance772 Mar 12, 2014 01:48 PM
Muskoka your awesome dude. Great So the housing is the different part and the other long piece the rest of the evaporator is the same. Will go work on that today. Also the new motor that I need to attach to the new housing on the driver side it doesn't fit correctly. Is there something I need to know
Muskoka Mar 12, 2014 02:26 PM
Hi
Rotate the door actuator ( on the plenum,that connects with the motor) with a screw driver, insert the motor until the three holes line up, screw in the three screws.
