2010-2014 Mustang Shelby/Kicker 8" Door Woofer Opinions*
Old Nov 16, 2011 | 08:55 PM
tyndallcbr's Avatar
Looking for opinions on the sound quality of the Shelby/Kicker 8" door woofers installed in a 11 GT with Shaker 500/Navi. I have read through several threads but there does not seem to be any information about the 11 GT Shaker 500/Navi combo... most are for older Mustangs or ones that don't have the Nav option and need a 4.1 amp from Shelby to go with the 8" door woofers.
Old Nov 17, 2011 | 05:18 AM
Bigblue11's Avatar
After two months i'm not sure it was a good purchase for me. I have the nav system also. I'm wondering if i had a sub in the trunk would it make it better. I would just upgrade the regular speakers if i could do it again. Plus the cover is made of Styrofoam or something...not a good quality for a cover.
Old Nov 17, 2011 | 09:36 AM
Locotone07's Avatar
Agreed. Don't do it unless you can add aftermarket amplification to them otherwise the output is miserably lacking when compared to stock...something I'm currently working on.
Old Nov 17, 2011 | 09:38 AM
Overboost's Avatar
I've been waiting for months to see what these look like installed...got any pics?
Old Nov 17, 2011 | 09:48 AM
Locotone07's Avatar
Not my pics but hereare some: https://themustangsource.com/f803/ha...4/#post6144912
Old Nov 17, 2011 | 09:55 AM
Overboost's Avatar
Originally Posted by Locotone07
There's no way the stock surrounds will work, right?
Old Nov 17, 2011 | 10:50 AM
Locotone07's Avatar
No, they won't.
Old Nov 17, 2011 | 11:40 AM
Bigblue11's Avatar
Here are some pics...
Attached Thumbnails 2010-2014 Mustang Shelby/Kicker 8" Door Woofer Opinions*-speaker1.jpg   2010-2014 Mustang Shelby/Kicker 8" Door Woofer Opinions*-speaker.jpg   2010-2014 Mustang Shelby/Kicker 8" Door Woofer Opinions*-speaker2.jpg
Old Nov 17, 2011 | 07:12 PM
tyndallcbr's Avatar
Thanks for the replies. Does any one else have any experiences with these sub woofers to offer?
Old Nov 17, 2011 | 07:27 PM
LEwis26's Avatar
I have em, and like them a lot. Very tight, and focused and controlled bass. Yes they're a lot less boomy than the stockers but I like the quality of midrange coming out of them. Just enough for me.
I had an alpine type r 12" with a 650 watt amp in my old car and it was insane power.
Now all I need is enough to get my grouch when the engine noise isn't enough. Trunk subs are a no no in the stang so I can fit golf clubs in
Old Nov 17, 2011 | 08:35 PM
tyndallcbr's Avatar
Do you think a trunk sub is needed to fill out the sound?
Old Nov 17, 2011 | 09:14 PM
LEwis26's Avatar
I don't think so, but some others might.
Old Nov 17, 2011 | 11:49 PM
CaptDistraction's Avatar
I wish these could be used with different covers. Those covers look like hell compared to the 2010+ covers.
Old Nov 18, 2011 | 07:04 AM
Locotone07's Avatar
There lies the problem...midrange, these are not supposed to sound like midranges but woofers or more specifically subwoofers. I know Lewis26 really likes them, his testimonial helped convince me to get them but perhaps someone else with experience can back me up. Connected to my stock Shaker 500 w/nav, base turned all the way up, I can barely hear them (and yes they are wired properly as per the Shelby instructions), I'm currently waiting for an AudioControl LC2i which I will be connecting to an Elf Audio 1500DM (wire these 2ohm Kickers in parallel) which I'm planning to mount under the front seats (trunk space in my vert is a premium) in hopes of getting them to sound right. I really didn't want to go this route but don't see another choice unless I go back to the stock subs. Of course YMMV...good luck but again I say unless you add aftermarket amplification or add another (larger) sub to the trunk...don't do it.
Old Nov 18, 2011 | 11:58 AM
Big Poppa's Avatar
I certainly do. I like a lot of clean clear bass and the factory NAV system just don't do it for me. My previous car I had the Skipper 1000 and it sounds a lot better than this thing. I don't trust anyone here to do such a job, but when I return to the USA I'm getting trunk subs and an amp or two.
Old Nov 18, 2011 | 01:19 PM
Bigblue11's Avatar
I have em, and like them a lot. Very tight, and focused and controlled bass. Yes they're a lot less boomy than the stockers but I like the quality of coming out of them. Just enough for me.
What year do you have? If its an 11' is your main amp in the passenger side of the trunk?
Old Nov 18, 2011 | 02:31 PM
Locotone07's Avatar
2012 and I believe the sub amp is by the driver side kick panel. The amp for the other speakers is in the passenger side trunk...anyone else with a 2012 confirm this?
Old Dec 22, 2011 | 12:33 AM
Locotone07's Avatar
Just finished my upgrade...
The additional amplification makes all the difference. I ended up wiring the kickers in series...plenty loud and clear. Finally sounds as it should.
Old Jan 4, 2012 | 02:50 PM
Tripleshot McC's Avatar
I installed the Shelby/Kickers the first week I had my car. I got used to the new grills pretty fast actually. And they are flexible, but have not broken (yet), so no issue there for me. I like not having the chrome ring around them, gives the lower part of the door less bling which I see as a good thing.
Now, for the important part, which is not how they look but how they sound. I have the Nav. and replaced the front door and rear side panel speakers with Pioneers at the same time. In my opinion, not enough improvement in either case. After 1 week, I pulled the trigger on the LCQ1 under the pass. seat and a 4 channel JL amp under the driver seat running the Shelby/Kickers and a set of Hertz separates replacing the Pioneers in the doors. I put the remote **** inside my center console compartment for the Shelby/Kickers. Now it sounds great. IMO, the Shelby/Kickers need more clean power than they get from the Shaker500 system and the bass roll-off kills them. The LCQ1 also takes care of the bass roll-off issue and I send only LF to the subs.
Pros: now it sounds great no matter how loud I turn it up (and that's pretty loud w/the top down) and I can control sub/bass output separately.
Cons: I am $1500.00 poorer after parts and install. I still won't win any hip-hop car audio contests because I still have room in my trunk for a suitcase and cooler! Wait, that's a pro, not a con.
Old Jan 12, 2012 | 10:58 PM
rudy5.0's Avatar
http://www.hifisoundconnection.com/S...id/0/SFV/30046
This kicker sub can be paralleled down to 1.1 ohms to match the impedance of the factory woofers. The Shelby subs are 4 ohm dvc and can only be paralleled down to 2 ohms. That will only use half the power of the factory amp where as the kickers in the link would use the full power.
