Not your Average Glass Roof Thread.
Well it’s happening...after toying with the idea since 2015 I finally found a glass roof and figured out a smart way to install the glass roof so I should start installing it early next month, I will try to keep this thread updated.
https://cimg3.ibsrv.net/gimg/themust...211c06515.jpeg |
1 Attachment(s)
So is this a top off a wrecked glass top car? Love to see the process from begin to end... Staying tuned in good luck. :nice:
Yes this roof is off a donor 2010 that was hit pretty hard in the passenger side quarter. My original idea was to buy the frame, glass, sunshade, headliner, trim all of tasca new but the total was going to be over 4k. So I managed to find this one and grab it for less than 1k. I still might need need black trim pieces ($500 each) plus pay for my body guy to help me install this as I cant weld for crap.
But I will try and take many pictures as we chug along. I want to get pictures of removing the old roof, dissembling the glass roof and welding the glass roof frame, just to name a few. |
Sounds like an interesting project. Keep us updated! Love my glass top, would be hard to have one without it.
Wow, quite a project!
I love my glass roof, and you will too. I did not trade up to a 2015+ only because there is no glass roof option, so I am keeping mine until they do. |
Interesting project, what are you installing it on ??
. https://s25.postimg.cc/vu4oc87qn/01-...4_PICS_009.jpg https://s25.postimg.cc/dfbv0cqwf/Bre...2-2013_007.jpg . |
3 Attachment(s)
Originally Posted by jim010
(Post 7028331)
Originally Posted by 1 Alibi 2
(Post 7028406)
Mine is going on my 2012/"2013" v6 base that has been upgraded to the 400a package with some 401a included, 2013 body and interior. 2013 shelby quads, some other things Im probably forgetting. Attachment 211613Attachment 211614 Just a pic to prove it was a 2012 base before I started touching it. Attachment 211615 |
6 Attachment(s)
Little update.
Over the past 2 day I have managed to figure out the previous owner put a tint on the glass so I spent an afternoon stripping the tint and adhesive off. Then cleaning it with glass cleaner, looks real shinny now! Attachment 211617Attachment 211619 Attachment 211620Attachment 211621 Today I found out while cleaning the sunshade that it was broken and wouldn't retract. :mad: So I had to spend today fixing it... turns out that not only did one of the shades rails come of the plastic guide but when it reattaches there is so much friction that it would not roll back and would just bunch up by the plastic handle. I fixed this by squirting some WD40 on the plastic rails and working the shade. It slowly got better the more I worked it. Its now buttery smooth. I then proceed to wipe off as much excess lubricant as I could to avoid getting any dripping lube on the headliner later. Some pics and video of operation after fixing. Attachment 211622Attachment 211623 |
1 Attachment(s)
Got the interior stripped today. Looking at the roof structure and frame nothing looks different between the glass roof and the regular roof so I think this will be a straight forward remove roof and weld in glass frame.
On a side note finally got to test the proximity sensor system I added to my car. Real simple. All cars are wired for the sensor already. All that has to be added is the overhead console with the sensor and a hood switch and run one wire back the the SJB. Then just reprogram the SJB and BCM-B with the correct programming.... 2011-14 cars do not have the security horn in the back of the car btw but 05-10 does? I dont know why.... Attachment 211637 |
My body-man swung by yesterday and he think this should be pretty easy and straight forward. I asked him if he though welding the frame would be better or cutting the pillars. He definitely thinks that welding the frame would be better. His only concern was if the windshield guys could take the windshield out without breaking it. But A new windshield is still work the glass roof to me so I still gave him the go ahead. Should be dropping it off on the 6th!
Is there any risk of the body sagging when the original roof is cut out, making it difficult to intall the new roof?
Very ambitious.
I'm excited for you. What you are doing is cool. You're going to love having this new roof! Don't forget to have your car appraised with this new mod for insurance purposes! And get full glass coverage. |
Originally Posted by SpectreH
(Post 7028827)
(Post 7028879)
Very ambitious.
So I just got done dropping the car off yesterday. Today the glass guys are coming to remove the glass on my car and on the roof. Cost me $300 to get all the glass removed and installed. Wednesday I should know more about how that goes. I will hopefully go back up there and start doing the actually bodywork on Wednesday. I will try my best to take pictures!
Please do!!
...and the suspense builds.
:popcorn: Looking forward to updates |
11 Attachment(s)
Update time!
Went over today and got some work done. My sheet metal roof is now off and the top of the headers are stripped off. Here are pictures of my car without the roof...really at the point of no return now.... Attachment 211743Attachment 211744Attachment 211745 Then we moved over to the donor part. We had to strip the frame that the glass sits on so it could be transplanted over. This was a ton of drilling. We first drilled all the spot welds with a 1/8" drill bit then went back over them with a spot weld drill bit. Then just a chisel and hammer. This is the frame without the glass on it for anyone curious...you can see my old roof in the background. Attachment 211746 This is about halfway through separating the frame from the chassis. You can see all the 1/8" holes in it from drilling out the spot welds. Attachment 211747 This is what the donor part now looks like without the glass frame on it. Looks just like whats on my car right now...same sub frame. Attachment 211748 Next we decided to do a dry fit of the frame. This is us dropping the glass roof frame onto the car. Attachment 211750 This is with the frame on from the front and back. Attachment 211749Attachment 211751 Starting to look like something. The next steps will be to weld in the frame and get it sanded (remove the urethane, smooth it all out, grind the welds down.) Then it will get primed and painted to match my L6 Kona Blue. Then we are waiting for the black trim that goes between the windshield and glass roof and rear glass and glass roof. Those are made from sheet metal and are impossible to remove without damaging them beyond repair....cost about $1000 in total just for those trim panels. After we put those trim panels in then the glass can go back, then reassemble the car! I should be going back up next Wednesday...by then the frame should be welded and painted. Then its just wait for those trim panels. On a side note finally got my reverse sensors painted and mounted...not bad. Attachment 211752Attachment 211753 |
Awesome work! I never realized those black panels were metal - I always thought they were plastic with how easy they scratch!
Very interesting build. Thanks for sharing. Looking great so far!
