Safety Loop Question
Hey everybody I've got a 12 Roush stage 3 and have the one piece Dynatec aluminum driveshaft. I'm wanting to purchase a safety loop that will work with a different driveshaft from the stock one. Does anyone have any suggestions on safety loops or has anyone installed one that is compatible?
Thanks, Dave |
Stiffler's is the one I use and it is probably the easiest. It mounts to the transmission cross member (three bolts)
Originally Posted by redonblackpony
(Post 6987707)
Fairly inexpensive and you don't even have to remove the driveshaft to install
(Post 6987709)
Actually yes, mine was vibrating the whole drivetrain because it was misaligned. The shop that installed my new clutch put it back in place. Took forever to diagnose the problem. Once i found out what it was it was a easy fix though.
Just push it up on the mounting bolts and tighten it, done. Let gravity work and it touches the X member and wow, noisy
don't forget about the blowfish bracket. It does double duty.
https://www.blowfishracing.com/drive...t-bracket.html |
So many choices
I'd split the duty and go MGW and Stifflers. The Blowfish is vibey, noisy and retains the stock style shifter mechanism. That said, I'm in an auto version now, so I don't really care :)
| All times are GMT -6. The time now is 09:04 AM. |
