-   5.0L GT Modifications (https://themustangsource.com/forums/f800/)
-   -   Resonator question (https://themustangsource.com/forums/f800/resonator-question-505348/)
Roelito78 Feb 17, 2012 12:35 PM
Resonator question
Hey guys, are the resonators in our cars directional? I removed my resonators a while back and re intsralled them recently. I wanted to make your I re installed correctly. Both resonators are smashed in from the factory. Does the smashed half face the front of the car or back of the car? Thanks
AzPete Feb 17, 2012 04:39 PM
Smashed end was towards the rear on mine. Pass. side down, drivers side up. I see nothing to make them directional looking inside mine. Just had mine removed last week.
Trailhawg Feb 17, 2012 07:54 PM
Why do you want to put them back on?
Roelito78 Feb 17, 2012 08:09 PM
Hey guys, thanks for the info! I had them removed and my Roush sounded very distorted and raspy. I decided to put them back on but for some strange reason the sound tone changed a lot comparing to when I first intalled my Roush with resonators. Not sure what else it could be
Hytek Feb 17, 2012 10:16 PM
If you're looking for a better sound with the Roush's try looking into an after cat xpipe rather than messing with the resonators. I finally had my FRPP one installed this morning and it sounds a lot better. The raspy/poppy sound is gone. It's more mellow/smooth sounding but yet a deeper bassy growl. WOT is amazing sounding without the obnoxious rasp it had at times. If I had to compare it, think of the older 5.0's with a nice exhaust. The 1% of drone is completely gone and highway cruising is darn near stock silent. I had it installed because fitment is bad on the FRPP ones. I didn't get a chance to do a video yet, but I'll try and get one this weekend.
Roelito78 Feb 18, 2012 05:27 AM
Thanks Hytek! Will look into the x pipe
2012GTCS Feb 21, 2012 02:34 AM
Hytek, did the shop say fitment was off a little?? Who did it and how much?
Hytek Feb 21, 2012 08:36 AM
The shop that did it said it was about an 1/8 inch shorter than the stock h pipe. When they first got it on it leaked bad after the cats. They said longer clamps would've helped. The way they got it to fit was by tightening it up at the cats first and then pulling the over axle pipes in to it. It's been about 300 miles since install and no issues. Sounds sexy as hell! Merlin's did the install for $50.
My reccommendation to you and OP, unless you have a lift or experience with these I'd let a shop do it. They fought with it pretty good, I can't imagine trying to do that on jack stands.
Nocturnal'14 Feb 21, 2012 08:40 AM
REALLY DEBATING my exhaust setup here!
I have the GT500's now, but am contemplating these two options:
Option #1: Cut the Resonators and add the JBA 3" H-pipe = $375
Option #2: Buying the ROUSH square tip Axle Backs w/valance (sell my GT500's for $150)= $475
1. Which would be deeper yet louder than what I have now!? I do NOT want high pitch rasp!
2. Which would give better performance!?
Thoughts!?
way2qk4u2c Feb 21, 2012 08:45 AM
roush with the x pipe---youll be happy with the results
Hytek Feb 21, 2012 08:50 AM
Option #2: Buying the ROUSH square tip setup & Leaving the Mid pipe and Resonators alone = $618
Thoughts!?
Neither will really add much power and both would be deeper and louder. H pipe will make it louder, especially with no resonators. If you go the roush route, I'd have to say the after cat xpipe is a must. It's deep, no rasp, and sounds killer WOT.
Btw the square tips have grown on me and I wish I would've got them with mine.
LEwis26 Feb 21, 2012 09:22 AM
Love my square tips!
Once I hear John's car in person, I might get an x-pipe as well.
Nocturnal'14 Feb 21, 2012 10:04 AM
That's not a cost effective option......if I get a mid pipe it would be cheaper to just keep my GT500 mufflers.
Its either new mufflers / valance........OR ..........mid pipe / no resonators / GT500's.
Hytek Feb 21, 2012 11:05 AM
PM Steve from PureSpeedMotorsports on here. He's a Roush dealer and might be able to give you a good deal on the exhaust and valance leaving $ left over for mid pipe.
JPMotorSport Feb 21, 2012 05:56 PM
2nd this - I have the Corsa after-cat x-pipe rather than the Ford piece and I must say I really like the smoother, more sophisticated sound vs the H-pipe. O, and flow above 4000 RPM seems to be a little better, found that out after showing a modded 335i my taillights.
mbreinin Feb 23, 2012 05:38 AM
Just don't try to run a Roush with no cats and resonators...unless your pain threshold is high. :-D
Mike
Nocturnal'14 Feb 23, 2012 09:03 AM
Just finished ordering a JBA 3" in 3" out H-pipe from American Muscle!
Going to have my Exhaust shop weld 3" pipe in place of the Resonators when they install the mid-pipe.....
I will report back with sound clips Before and After!
32Fountain Feb 23, 2012 08:41 PM
Looking forward to hearing the before and after. Thanks in advance for sharing.
mbreinin Feb 24, 2012 01:00 PM
I am replacing the straight pipe where my resonators once resided with 3 inch Dynomax Bullets tomorrow. I am hoping the Bullets will help with the rasp that I have with my offroad X setup, and I would not mind a small reduction in volume. Even with the current mufflers, Dynomax Ultra-Flows, it is a pretty loud setup. Once those cats go.....it is a whole different ballgame.
Mike
Blackbird. Feb 24, 2012 02:46 PM
Right now I'm running just hush powers. I like the tone but I want more volume. It seems like resonators will do that but will introduce rasp. Do you guys think just getting the boss quad exhaust will do the trick?
