-   5.0L GT Modifications (https://themustangsource.com/forums/f800/)
-   -   Engine Vibration (https://themustangsource.com/forums/f800/engine-vibration-488991/)
mdun6 Nov 8, 2010 03:48 PM
Engine Vibration
Hey all, I have noticed that when I rev the engine at at about 1000-1500 rpm's it has a bad viration then goes away as rpm's go above about 2,000. Have any of you noticed this with your 5.0's? should I be worried? Could it be the aftermarket tune causing this?
mdun6 Nov 8, 2010 06:58 PM
I put the stock air box back on and returned the stock tune back in the ecu. Still I have a vibration around 1,500 rpm's. I guess it will be off to the dealer unless someone here says there car does the same. Maybe the vct adjusting?
Lancel Nov 9, 2010 09:56 AM
I really haven't noticed anything like this, sorry. :/
assasinator Nov 15, 2010 07:37 PM
bolt on the clutch probably backed out or broke off. its happened a thousand times already.
mdun6 Nov 16, 2010 04:07 PM
OK where is this bolt? More details would be great.
caps Nov 16, 2010 05:01 PM
dealership
montreal ponies Nov 16, 2010 05:22 PM
I don't think it could be clutch related, but could you give us more details on the kind of vibration you're hearing and where youn think it's coming from. Is it vibrating while driving the car or when it's idling only ?
assasinator Nov 16, 2010 06:52 PM
plenty of pressure plate bolts have backed out. yours and mine can do it at any time.
there is a inspection port on the bellhousing or go to the dealer.
assasinator Nov 16, 2010 06:54 PM
go to the track with sticky tires and do 6k drops. youll find a vibration soon enough.your clutch WILL fail after enough runs.
White2010 Nov 16, 2010 06:59 PM
If the vibration was really bad it seems like one of the knock senors would give an MIL. I'd still have it checked though.
mdun6 Nov 16, 2010 07:00 PM
I only feel it around 1,400RPM to about 1,700RPM. I don't notice it when i'm driving just when revving the engine at a stop and it shakes the whole car. My 15yo son could even feel it in the passenger seat.
assasinator Nov 18, 2010 02:45 PM
a vibration with an accleration higher than 7 mils, will ruin it pretty quick. get it check before it taers itself up.
mdun6 Nov 19, 2010 05:45 AM
I made an appointment for Tuesday to have it looked at. At least i'll have it on record.
mdun6 Dec 1, 2010 01:52 PM
Finally got my car into the services department yesterday and got the answer I thought they would give "this is a normal characteristic for the 5.0". There is a TSB for it now but it stated no repairs should be attempted.
Airassault Aug 14, 2016 10:44 AM
got a 2014 5.0 gt/cs and just had the clutch replaced. Ever since I got it back I've noticed a vibration at 1100 RPM's. Could this be the pressure plate bolt you're talking about?
SpectreH Aug 14, 2016 06:05 PM
I'd guess the flywheel/pressure plate need to be balanced.
