Drag Rims & Tires 2013 GT
I have a 2013 Mustang GT, It has 19 X 8.5 rims on it, I don't believe anyone makes a Drag tire in that size.
I see 15" seems to be the way to go. What do I need to do to fit big rubber under the rear of my car?
The low profile tires just won't hook up worth beans on the track.
All you need is a 15x8 rim and run a 275 drag radial. You might check out LMR since they have nice drag wheels for around 150 bucks each. If you go to a 15x10, you will have to install sway bar relocation brackets, but plenty hook up with using what I mentioned above.
