-   5.0L GT Modifications (https://themustangsource.com/forums/f800/)
-   -   Custom tune @ tire size question (https://themustangsource.com/forums/f800/custom-tune-tire-size-question-518767/)
Tron84 Feb 17, 2013 08:50 AM
Not that I am running a staggered setup (285/40-18 X 255/45-18) what tire size do I put in when requesting new tunes?
I assume the front tires due to the speed sensor? Not sure though....
mikeyt03 Feb 17, 2013 12:35 PM
You want to find out the tire revolution for your specific tire. Each brand is different even in the same size.
smitty Feb 17, 2013 12:42 PM
I always assumed the rear tire size as I think the speed sensor is located where it can read the transmission output shaft? but I don't know for sure. Good question. :dunno:
Ministang Feb 17, 2013 01:05 PM
In your case, it doesn't matter which size you enter, as both tire diameters are virtually identical, less than 1% difference.
Tron84 Feb 17, 2013 04:53 PM
That makes it easy, what if they weren't that close?
sloppymax Feb 17, 2013 05:32 PM
Reading will be based on the rear tire.
Tron84 Feb 17, 2013 07:12 PM
Ok so I just put in an order for new tunes from bama, it asks for REAR tire size.
Guess I never noticed that before.
2012GT Feb 17, 2013 10:22 PM
Rear tire size diameter is the issue. I used my GPS to dial it in exactly by mph. Even the tuner setting was off when I put on the new tires by putting in the new diameter. I had to do a little trial & error. Speedo is now 100% correct.
