-   5.0L GT Modifications (https://themustangsource.com/forums/f800/)
-   -   Cat deletes (https://themustangsource.com/forums/f800/cat-deletes-526686/)
bud4au01 Nov 29, 2013 03:53 PM
Cat deletes
Anybody put them on ? What differences should i expect other than bit louder?
Ltngdrvr Nov 29, 2013 09:26 PM
You get higher flow out of them, but remember, they require a tune or it will throw a code.
DarrenGT Nov 29, 2013 09:34 PM
new to modding here so what are cat deletes?
DinoDoc Nov 30, 2013 02:02 AM
cat deletes are pipes that go in place of where your catalytic converters go that have bungs welded in so you can still have your O-2 sensors in the exhaust. This in turn is much less restrictive thus freeing up HP, and makes the car a bit louder. When you delete the cats you have to have your tune adjusted to compensate for the change in back pressure ( I believe) and have your O-2 sensors turned off so the computer doesn't give off a fault code.
GrabberBlue5.0 Nov 30, 2013 05:50 AM
A tune doesn't compensate for any changes in back pressure. It will do two things. Turn off the rear o2's which monitor the cats and also on these newer cars will turn off the COT feature. Nothing more.
DinoDoc Nov 30, 2013 03:55 PM
Thanks for clearifying that, see you learn something every day.
steve03gt Dec 2, 2013 08:55 PM
COT feature? You'll definitely notice more sound, raspier, and seem to free up power.
GrabberBlue5.0 Dec 3, 2013 03:51 AM
Originally Posted by steve03gt (Post 6722666)
COT feature?
COT=Cat Over Temp
steve03gt Dec 3, 2013 11:27 AM
Figured that was what it was, but couldn't figure out the acronym
70monte Dec 3, 2013 05:41 PM
Isn't it against the law to remove the cats and if you are found out, aren't there big fines involved? I thought the cats on most new vehicles were pretty free flowing and that you don't see much power increase by removing them.
Wayne
Stage_3 Dec 3, 2013 06:09 PM
Wayne
It is against the law in MA. You can get high flowing cats aftermarket as well.
Plus, like you said, it doesn't free up a ton of horsepower.
ted2006 Dec 3, 2013 10:09 PM
illegal in all 50 states
DinoDoc Dec 3, 2013 11:54 PM
I thought I read some where that you could gain in the neighborhood of 15 HP with a off road X-pipe with cat deletes, Is this true?
Lee
GrabberBlue5.0 Dec 4, 2013 02:37 PM
Lee
True.
Toxix Dec 10, 2013 06:44 PM
Good info here.
Do highflow cats provide the exact same power output/results as cat deletes?
How do high flow cats sound compared to no cats?
PS - 2014 GT here with Rough Axlebacks and Resonator Deletes already, heh.
GrabberBlue5.0 Dec 11, 2013 02:25 PM
Originally Posted by Toxix (Post 6728205)
Good info here.
No they don't.
Fudge Dec 19, 2013 04:53 PM
I was thinking of doing this myself (actually bought them already) in your opinion (for those that have done the cat delete) are they worth it? do you get drone?
woodzusa Dec 19, 2013 05:55 PM
I have a convertible with the quad gt500 exhaust. I decided to remove the cat's using the jegs delete pipes. Fit was good, although we had to adjust the driver side to get rid of an exhaust leak.
Now, at first I thought they were too loud and the fumes were a little strong. Well, I guess the fumes killed some brain cells because now I love to hear them. And I no longer get an strong odor. There is some but not overpowering.
In the vert, it is loud during hard acceleration but tame when cruising.
People have their own opinion with and HP/TQ gains. But it seems more responsive since they were removed.
dreday23 Dec 21, 2013 06:46 PM
yea i just got my steeda cat deletes installed and there is definitely something about the drivers side that doesn't allow aftermarket pipes to connect to the h pipe correctly. after using permatex and adjusting the clamp while the car was running theres still a very slight exhaust leak on the driver's side with the permatex being fresh. the passenger side doesn't leak however.
Fudge Dec 23, 2013 10:26 AM
The odor were talking about is fuel, I'm gonna guess, how bad is it? I start my car in a garage so the engine builds some heat before I leave, would this be bad? Is it syringe bought that idling for 2-3 minutes will cause me unintentionally commit suicide?
Or is is just a bit stronger than stock?
I noticed a bit of a fuel smell just going with a Steeda 93 octane tune, on guessing this will be more than that?
Or since the cats aren't doing anything anyways till they warm up the initial start up is not gonna make too much of a difference?
