camshaft on cayote?
Old 2/25/11, 11:58 AM
Ducky's Avatar
Originally Posted by FastRedPonyCar
I susupect that the custom tune would take care of that.
The new cams would require a new tune more than likely anyways as it would be using the variable cam timing differently than stock (I would assume)
anyways, these cams/heads/intake/exhaust, etc all sort of build off of each other synergistically. One component alone isn't worth much but adding the ported heads all of a sudden make the intake flow a lot more = more power.. same with different cams and higher flowing exhaust, etc. I'm probably preaching to the choir here though
Hahaha no, there is no tuning past 7800. There are no fuel or spark maps past that point. All tuners in the country take the stock tune and tweak it, they aren't writing the code to control the engine.
Old 2/25/11, 12:25 PM
FastRedPonyCar's Avatar
ahah that's when guys will start using their own stand alone solutions.
Old 2/28/11, 09:53 AM
hawkeye18's Avatar
I bet the BOSS 302 ECU has tuning beyond 7800.
Also, anybody who seriously uses the word "synergistically" in a sentence needs to be tazed.
Old 2/28/11, 09:54 AM
you should hang out with more IT managers.
Old 3/2/11, 02:00 PM
hawkeye18's Avatar
I'll bring my tazer.
STOERKEL
9/11/15 11:38 AM
TMSBrad
5/3/10 11:06 AM
TJ06
V6 Performance Mods
28
12/7/05 10:45 AM
Quick Reply: camshaft on cayote?
