Borla s type catback tip adjustment..
Hey guys, just installed my borla exhaust and it sounds awesome... One problem tho, one of my tips stick out about a inch and a half more than the other. Where do I need to adjust at to fix this????
Not being sarcastic at all, but a quick 30 seconds with a grinder will be all you need. You could try loosening every step on that side first though. Cats and the midpipe joint to the cats, then work your way back.
Lossen the band clamps that connect the x-pipe and over-the-axle pipes...then you can move the over-the-axle pipes forward and backwards, then move the axleback forward and backwards in the rubber grommett to get the right amount of tip shown.
Sep 10, 2015 12:44 PM
