Bama V2 tunes
I am showing my newbiness in here.
For my tunes, I ordered 93 octane performance and 93 octane race tune, since I always use 93 octane. What happens if I drive to a state where 93 is not available? Should I have gotten one 91 octane tune?
Alex
Alex
I too have the older Bama tunes and the SC3 tuner. Im in the process of getting the version 2 tunes. I have no problems with my current tune. Ive just heard the version 2 tunes are better, so Im going to try them out. I hate to fix something that's not broke, But im going to roll the dice.
Let me know what you think once you've put a few miles on them, I'd love to get your feedback!
Alex
Alex
You install the tune. Then you data log. THat is driving around while your tuner records the data from your PCM. You send the datalog back to Bama so that it can be analyzed to insure yoru ignition timing is correct and fuel/air ratio's are good, etc. If somethign is a bit off they may make adjustments to yoru tune file and have you re-load then re-datalog to insure the changes were correct.
You can analyze your own data log with Live Link. it's great software and its free. http://sctflash.com/LiveLink.php
14GHIG - Thanks so much that's hands down one of the best explanations I've ever seen on a datalog!
dohc97 - The Bama Team can walk you through exactly what you'll need to do and it's very easy. Once you pull all the data it's sent back to the Bama Team and looks like this!
Cool stuff right!?!?!?! Lots of numbers for the Bama Team and Myself to piece through - It gives us both a better idea of how your cars operating and allows the Bama Team to further refine your tunes just as GHIG had said!
Hope this helps guys!
Let me know if anyone has any other questions!
Alex
I am in the process of requesting 2 additional tunes. I am thinking of getting an 87 performance and 91 race tune to go with my 93 performance and 93 race tunes. I always fill up with 93 wherever it is available. The 87 is just for emergency when I can't find a 91 or 93.
What tunes do you have in your tuners?
Anytime! Sorry about the delay guys, I sit on about 10 forums and I have a few other side duties while I'm here as well - I try to be on the threads as much as I possibly can (Not a bad gig right!!?!)
Alex
Let me know if you're to have any other questions at all and I'm here to help!
Alex
Anytime! Believe me we want the Bama Team to get this out as quickly as possible! It's hands down one of the most recommended tunes to get moving on. The difficulty with them is due to the cats and when they previously offered them you needed to have an O/R Mid-Pipe - Paul and the Bama Team are tuning and tweaking these so that when they're brought back out we should be able to run them on catted cars!
Let me know if you have any other questions at all and I'm here to help!
Alex
Alex, earlier today I ordered a Raxiom tail light sequencer. Then I received an email from you guys about a free Bama banner if I order at least $100. Can I still qualify for that free banner?
I'd be interested in the banner as wheel. Just bought two front amr rims before the St Patrick sale was introduced. Also bought my tunes for life like a month ago.
I uploaded my v2 93 performance tune today. The first time I started the car, it sounded okay. I didn't have the chance to drive the car as I had to be somewhere else and I drove my other car. I just got home 10 minutes ago and I started the car again with the intention of test driving it. As soon as it started, it didn't sound right. There was the lit wrench symbol in the gauge cluster. There was also a lot of smoke in the garage. I turned it off and restarted it again. Same thing happened. The idle normalized after about 2 minutes. Any clue on what happened in here? I am going to reinstall the stock tune tomorrow morning.
Keep me posted I am curious.
So this is what I did this morning.
I started the car, still with the 93 performance tune in it. It sounded the same as last night. It sounded a little bit lumpy as if it has a mild cam in it. It smelled gas.
I then reinstalled the stock tune. When I first started the car, there was a small amber wrench icon in the middle cluster, by the Ok sign in the Open door warning. It went away after a few seconds and never came back. The car idled normally, ran it for about 4 minutes. I restarted the car again, and it again idled normally.
I reinstalled the 93 performance tune. It idles normally this time. I am going for a test drive and will try to do a data log.
I drove my car for a total of 90 miles today. 40 of those, I have data logged. I drove it in the highway and in some tight, twisty, rural roads I used to ride on when I still had a sportbike. Coming out from a turn in third gear, hearing the Corsa axleback and the MRT H pipe in full song is so much fun. The extra grunt is very noticeable. And I was just using the 93 performance tune. Another thing I noticed is that the low speed surge I used to have is now gone.
Of course, I had my windows down the whole time.
How do I get the data log off the SCT device?
Alex
Let me know if you have any questions in the meantime and keep me in the loop!
Alex
Interesting. Maybe the the file is corrupt?? I would agree with your course of action. Re-install the stock tune and get a new file just to be safe. Then retry. The god news is nothing was damaged. Sounds like the fuel map may be off and the catalytic converter was loading up with fuel. It will clear out and everything will be OK.
Alex
Alex,
The first thing I did with the tuner was check for any updates. Result says I have the latest version and no update is needed.
I just had to uninstall the tune and re install it back. It worked perfectly for the 90 mile drive I did yesterday. The engine sounded healthy and it was pulling very strong. Will keep everybody in the loop if I develop any other issue.
How do I data log? I am not sure if I did it correctly yesterday.
Alex,
Let me know if you want me to have one of the guys shoot you a call on this!
Alex
Alex or anyone else,
I have a SCt X3 tuner I bought a couple years ago from AM as a CAI and tune package for my old V6. I now have a 2011 5.0. Can I wipe it and still use this to download and install a new tune I purchase from bama or anyone else? Or do I have to sell it and get a new one?
I have a SCt X3 tuner I bought a couple years ago from AM as a CAI and tune package for my old V6. I now have a 2011 5.0. can wipe it and still use this to download and install a new tune I purhcase from bama or anyone else? Or do I have to sell it and get a new one?
Did you restore the V6 car to stock and "unmarry" the tuner from it?
