Sponsored by:
Sponsored by:
American Muscle 19" Staggered GT500 Wheels
Old Jun 4, 2013 | 02:10 PM
jake80's Avatar
Any one have these on their 2011 Mustang.
These came on my car and I noticed the rear lug nuts stick out further than the ones on front wheels.
Called AM and they said that their lug nuts should not do this. However if the front ones are the same as the back then I would have same result. AM said they are all the same lenght.
Went to Pep Boys and they did not have anything different that what is on car.
If anyone has these can you let me know if you have the same issue.
Regards,
Jake80
Old Jun 5, 2013 | 09:26 AM
AMDanBailer's Avatar
Former Vendor
Regards,
Jake80
I've never seen any issues like this, but we can definitely look into it for you. Post up some pictures of your car, so we can check out what you're seeing!
You can view customer submitted images on our website and you'll see what our wheels and lug nuts look like! I hope this helps. Let me know if you have any further questions!
-Dan
Old Jun 5, 2013 | 09:59 AM
ShaneGT's Avatar
I have the 2013 AM Gt500 wheels, i can post pictures of them on my 2011. I got the gloss black acorns from AM, and they all sit flush front and rear. Could car have a spacer or longer studs?
Old Jun 5, 2013 | 10:02 AM
ShaneGT's Avatar
All i have with me, Ill take a shot of them closer tonight for you to see. I have the 19 inch staggered with 10 inch rim on rear, 275s.
Old Jun 5, 2013 | 12:50 PM
Trumpetlon's Avatar
I have the 2010 GT500's in 18" and have the same fitment with the lug nuts. The front are flush and the rear stick out. I think it has to do with the offset on the 10" rears.
Old Jun 6, 2013 | 06:25 AM
stang8psi's Avatar
Its the offset and the fact that they are a concave wheel , every wheel that is designed as a concave rear wheel will have this effect on the lugs.
Old Jun 6, 2013 | 05:37 PM
jake80's Avatar
Info on lugs
Thanks for all your input and confirmation of same condition with offset 10" wide rear wheels.
They work fine however would look better if they sat flush like the front.
Regards,
Jake89
Old Jun 10, 2013 | 07:51 AM
ShaneGT's Avatar
Well, somthings got to give when you try to shuve a 10 inch rim under there
ToddMcF2002
'10-14 Exterior Modifications
17
Aug 3, 2015 07:42 PM
